Just Joined, have a swapped 00 RS
Results 1 to 6 of 6
This is a discussion on Just Joined, have a swapped 00 RS within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; I read threads on here all the time and figured id sign up. I have a SRP 00 RS Sedan, ...
    Registered User iant333's Avatar
    May 2013
    Upstate NY
    I read threads on here all the time and figured id sign up. I have a SRP 00 RS Sedan, swapped with a built EJ205, VF30, ill just post a mod list below since there is tons of junk on the car. I'd say it is like 85% done with but there are still a couple things I want to add, new wheels/tires, 2/4 pot brakes, racing seats and a couple other little things. I've spent the past almost 3 years slowly building it and now that I have had it totally back together for a few weeks it comes time to enjoy all the work and money. 100% of the work on this car was done by me, i'm an ASE certified mechanic. Im bringing it to the drag strip for the first time just to see what it can do in a straight line in a few days, hoping to break into the 11s.
    Engine:
    EJ205, brand new 100% rebuild
    Wiseco forged 0.20 over pistons
    Eagle H beam rods
    04+ cross drilled crank
    ACL race bearings
    11mm JDM STi Oil Pump
    Brian Crower Valve Springs
    Stock Cams
    VF-30, Ported, and running 22psi
    Perrin BCS
    Perrin Fuel Rails
    Aeromotive Adjustable Fuel pressure Regulator
    Walbro 255
    DW 750cc Injectors
    Perrin Short Ram Intake
    Perrin Turbo Inlet
    APS Catless Turboback Exhaust
    Invidia Up-pipe
    Group N motor mount
    Perrin crank pulley
    Never had it dynoed, it was road tuned. I'd guess around 290ish wheel.
    Transmission:
    JDM 96 STi RA takeoff
    Group N Mount
    Kartboy Shifter bushings
    ACT Streetlite flywheel
    Competition stage 2 clutch
    DSS Aluminum Driveshaft
    Suspension:
    Koni/GC combo
    Perrin 22mm Rear sway
    Perrin 22mm Front Sway
    Cusco Camber Plates frnt/ GpN mounts in the rear
    Most bushings replaced with poly
    High Performance Alignment
    Brakes:
    Bugeye WRX Fronts
    Hawk HPS pads all round
    Brembo Blanks all round
    Wilwood Hi temp 570 fluid
    96 Brighton Master cyl (No ABS) and single stage brake booster
    Other:
    Seibon CF Hood
    A bunch of prosport gauges (
    WRX dash swap
    WRX seats
    Schroth Rallye 4 point Harnesses
    A bunch of weight reduction, still have a full interior but curb weight is down to about 2600lbs
    03 Bugeye Wheels w/ Toyo Proxes 4's
    Battery moved to the trunk.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Excellent build! Welcome! The tuner never gave you a dyno printout?
    Beamed at your face at approx. 186,000 miles per second via DROID BIONIC
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    May 2013
    Upstate NY
    Thanks alot. He road tuned it for me. I haven't had the ambition to drive to go to an AWD dyno, there aren't any around that I know of. The closest one I know of is at EFI logic in CT and I live in Albany NY.
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by iant333 View Post
    Nah, no big deal. A dyno is just a tool anyhow.
    Facebook me here
    Captain James of the SS Impreza has gone down with the ship Drews's Avatar
    Aug 2008
    Davey Jones Locker
    Too many doors. But still...sweet car, welcome. I'm in the process of finishing my 98RSTI.
    Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
    Stable: 2014 Hyundai Veloster Turbo (Matte Grey), 06 LGT, 98 RS, 16 Crosstrek
    Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
    Never argue with idiots. They'll drag you to their level and beat you with experience.
    Hey, Ian! If you want to try to do the reflash on Sunday, I should have some time...
    Synapse has one
    Resident Tuner @ WTF Tuning
