Slow speed brake issue
Results 1 to 12 of 12
This is a discussion on Slow speed brake issue within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Hey fellas! I'm stan just got a Wrx beautiful looking car ill put a pic up if I can work ...
    Apr 2013
    A, A
    Hey fellas!
    I'm stan just got a Wrx beautiful looking car ill put a pic up if I can work out how to do it
    Anyway when I come to stop prob around 10-5 ks with foot on break its like the hill start is trying to lock in or something
    And I know it dosnt work is there a part u can buy to fix this or remove as it makes a bit of a noise when I go to pull up cheers ??
    Registered User Mike193's Avatar
    Nov 2011
    North Jersey
    Idk much about the brake problem, but personally those wheels pose a problem. They look like they belong in the 'ghetto' on an early 2000's GMC Denali. But honestly, the more I look at them, the less harsh they become.
    Apr 2013
    A, A
    Ok well didn't ask for opinion on rims they came with car and they look fat to me but thanks I think ?
    Apr 2013
    A, A
    I'm from Australia have never seen a Denali until right now I know wat u mean about rims now these are 19 inch advanti
    Dec 2011
    Pottstown PA
    how many miles on the car? how many miles on the pads and rotors? warped rotors? wheels not balanced correctly? car unaligned?
    seems like you have a good amount of mods since its really low and i can see an FMIC. what are all your mods?
    Marky Mark
    My bugeye build
    MinoskePhotography
    Aug 2012
    Tucson, AZ
    I don't understand the question
    Dec 2011
    Pottstown PA
    also by yourusername i see the vf as a mod lol..
    but anywho i dont believe on that model theres a hill assist..unless that was an overseas option.. but maybe its your ABS kicking in early?
    trying pulling the ABS fuse and make a few stops and it could be the ABS...if it still does it plug the fuse back in and then my guess is its warped rotors or maybe the pads. can clean the pads and get the rotors resurfaced. but answer the question on the mileage on the brake rotor and pad mileage and that will be more help
    Marky Mark
    My bugeye build
    MinoskePhotography
    Apr 2013
    A, A
    Wink
    The car has done 130,000 kms mods are bigs plasma fmic pod filter intake vf22 turbo have lifted up around 50 mm with all new coils brakes are fairly new ill try pulling the abs fuse and see what happen only had the car for 2 weeks going to get it dynoed and tuned soon see how many horses she's pulling
    Aug 2012
    Tucson, AZ
    brakes are fairly new, so say they have about 8mm or so of pad life. then take into account that youre supposed to replace/resurface rotors each brake job. also check your master cylinder reservoir level. if its too high you may be causing your brakes to drag
    Apr 2013
    A, A
    Ok so pulled the abs fuse seemed to do the job but leaves abs light and hand brake light on which is a real pain still don't understand why it's doing it
    Apr 2013
    Kraków & Poland
    great home is a great verande
    Dec 2011
    Pottstown PA
    Quote Originally Posted by Vf22 Wrx 03 View Post
    ok so seems like its an ABS issue and not the warped rotors or whatever else. Does this problem occur every time you stop? Do you notice the problem when braking on loose surfaces? Plug the fuse back in and try braking on loose surfaces and report back.
    My ABS did what seems to be similar to this. It would kick in early on loose surfaces like snow, small rocks on the road. There is a recall out for that problem, where the Subaru dealer will replace the ABS ecu for no charge so the problem will not occur anymore.
    Marky Mark
    My bugeye build
    MinoskePhotography
