deceleration noise.....aarrrggghhhh
Results 1 to 12 of 12
This is a discussion on deceleration noise.....aarrrggghhhh within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; hey guys i got an 2004 wrx pretty standard, and had a reasonably kind life with 124km,s but just recently ...
    Mar 2013
    hey guys i got an 2004 wrx pretty standard, and had a reasonably kind life with 124km,s but just recently i started to hear a grindng like noise when decelerating with no clutch at about 4000 to 3000rpm, mostly in 3rd 4th and 5th... i looked around for anything loose climbed under the car and put it on a hoist were it didnt want to make the noide has anyone had a similar problem, im thinking flywheel/trans, its driving me mad the car seems to run as normal,
    Jan 2005
    Eh, whaaaaa?
    Had that problem on my '02. Exhaust was rattling in all kinds of places. Depending on the noise, though it could be just normal deccel noise, unless it's actually gotten worse recently.
    When was the last time the trans fluid was changed?
    Cody
    Mar 2013
    yeah its started to get worse, started off pretty faint but getting louder, cheak around all the heat sheilds but no luck, done fluild change bout 40000kms ago but did recently put a silicone like additive in the box but didnt really make much difference, i will drain it out again over a magnet and hope for the best
    Registered User SKI.WRX's Avatar
    Jun 2010
    Colorado
    Is the noise affected by turning the wheel? My buddies Forester had a bad front diff and it was noisy on deceleration and clunked on left turns more than right.
    Dec 2011
    Pottstown PA
    ive had my exhaust rattling and hitting under deccel but have fixed that and now its just the normal deccel trans whine. there should be a grinding sound though. try changing the fluid and normal shaving stuck to the magnetic drain bolt are fine but no big chunks of gears and such
    Marky Mark
    My bugeye build
    MinoskePhotography
    Mar 2013
    im not sure ill take it for a squirt and try turn while on decel see what i hear, cheers, what i have noticed is extreme wear on the inner tyres, in like the last 15mm, almost like a lathe has took a groove out of the inside only on the front two!!
    Mar 2013
    i think i better get it on the hoist again and check all the heat sheilds and exhaust again before i start digging much deeper, also a trans fluid change
    Dec 2011
    Pottstown PA
    Quote Originally Posted by mickstar View Post
    whens the last time youve had an alignment or do you know the specs of your current alignment?
    Marky Mark
    My bugeye build
    MinoskePhotography
    Mar 2013
    i got it done with the tyres that were on their bout 10,000kms ago but they are the one that chopped out so i gota couple new ones on the other day but they coulndt fit me in to get it done so im taking it in next week, didnt pull to one side or anything thats what surprised me when i seen them chopped out, not sure what the most recent alignment was but hope uts better this time round any suggestions??
    Mar 2013
    STRUCK GOLD!!!!!!!! After your post ruh roh i put the rex back in the shed and went through the exhuast system again but with no bolt left untouched and found the turbo sheild was loose and the baracket joining the first cat converter to the trans bolt was missing, although it was flush with the trans and unable to see it was missing from underneth i found it by feel,cant believe that it could make a noise like the trans was eating itself, took for a well desevered squirt and back to the normal deccel noise cheers for the advice that noise was sending me mad
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    My trans just makes a ton of noise. All the bushings and mounts don't help...
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Banned for Ageism 96accord's Avatar
    Mar 2007
    Baltimore, Maryland
    That's why I haven't upgraded my bushings. I hate noises. lol
