Soon owner of 2004 wrx in ATL GA!
Results 1 to 13 of 13
This is a discussion on Soon owner of 2004 wrx in ATL GA! within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Little about me. My name is josh and I live In ATL ga. I'm 22 and have had the same ...
    Registered User Jboyd's Avatar
    Mar 2013
    A, A
ID:	112275Little about me. My name is josh and I live In ATL ga. I'm 22 and have had the same vehicle since I was 16, a 1998 dodge Durango v8 4x4.. I found a 2004 silver impreza wrx at a local buy here pay here place as I have a crappy 500 credit score. It has 112,000 miles on it. And it's a 5 speed. I don't believe it has any mode except for I noticed it has an sti logo by the gear shift. Don't know if that matters. I should be able to purchase the car this week of I can come up with down payment. I wish it was white but paint jobs are expensive. I'm trying to found out how quick the stock wrx is in comparison to other cars stock. Say like a civic si or cobalt ss or Evo VIII. Sorry if those aren't in same league I don't know much but getting into the car scene now. It seems all wrx I see look a lot better then the one I'm purchasing. I think it cause they are lowering their cars. What are some upgrades to look into first ? I'd like it to be quick sound awesome and look amazing. And maybe what's rough estimate on some items. I have researched around but only info I find is on already modded wrx. And idk what parts I can get without having to get something else with it as I don't know too much about engines. I think lowering it with some white wheels and a good exhaust and bov would be awesome. Idk how fast the cars are yet tho to decide if I need upgrades there first or not.
    Jan 2012
    Philly Area
    Welcome!
    See the link in my sig for a good place to start reading about modding these cars.
    BOVs are generally frowned upon, unless you get a recirculating one. See here for more info on that.
    Lowering: Be aware that once you lower past a certain point, you are actually probably hurting the performance of the car. Generally the advice you'll get here is that you should go with a good strut/spring combo with a bit of a drop unless you are making a track machine.
    Finally, when you say exhaust, are you just looking for noise? If so, then look at catbacks. Anything more than that will require a tune as well.
    - Will
    Jul 2008
    sussex county, new jersey
    Welcome to the forum Jboyd! Just wondering if you know any info about the car like any maintenance that has been done or what has been replaced. Around 105k you want to replace the timing belt, and since this car is at 112k it might be something you would want to look into, quite a costly fix for just buying a car.
    As for Mods, I would say get a feel for the car first. Like you said your first car was an Dodge Durango, which is quite the opposite of a wrx. So learn the car, know its limits, know your limits and decide from there. Good luck!
    Mar 2013
    A, A
    Thanks for the welcome and quick reply. Prob just want Exhaust for noise unless I can find one cheap enough that give a little performance boost. Idk how quick these cars are stock. I won't be taking it to track or anything just something fun to drive on the weekends. Only like bov cause of the sounds. I like the way a lot of wrx look but I think they are sitting lower then mine. Ill post a pic of the look I want to aim for.
    Mar 2013
    A, A
    Quote Originally Posted by kord9 View Post
    Thanks for your response. And I honestly don't know anything about the car. I assume that's something I should ask the guy at the car lot. Thanks for that cause idk what a timing belt even is haha. He only want $11,900 for the car as well. I have pics of the engine if that would help at all
    Jul 2008
    Yeah no worries. Here is the maintenance schedule for the '04 wrx:
    http://www.subaru.com/content/downlo...04SchedFed.pdf
    As you can see at the 60k mark the spark plugs and fuel filter should have been replaced, which are certainly key. At 105k the drive belts and timing belt (aka camshaft belt) should have been replaced as well. You can print that out and use it as a guide to ask questions and find out what has or has not been replaced. And just because something was not replaced does not mean that the car is not running well, I did not replace my timing belt until 112k but at that point the car had a very rough time starting, so I knew it was time. But use your judgement or even bring someone you know that knows cars. Who knows maybe if there is something you can get the price dropped
    Mar 2013
    A, A
    Okay awesome thanks for that!! Happen to know what size wheel and tire I should look for as the stock ones look lame
    Jul 2008
    Sorry man I am not sure off the top of my head. Have you been to the dealership yet to check out the car?
    The Member michaelwfox's Avatar
    Nov 2011
    North GA
    Welcome to the forum! One thing I think you might want to consider is you first want to make sure you are buying a reliable car. No use putting the cart before the horse if you know what I mean
    Ask the dealer to provide as much service history as they can. If the timing belt was not replaced you can expect to pay near $1000 for that very soon after you buy it. Try and use that to your advantage.
    If you do end up buying the car I would recommend to first make sure it is fully up to date with routine maintenance. I know this is all boring stuff and you're ready to start modding but, like I said that isn't the first step. You don't want to start throwing mod money at a car that isn't going to get you around.
    To answer some of your questions: These cars are relatively quick in stock form. They are not EVO fast by any means but certainly faster than a stock Si. It is generally best to drive the car in stock form for quite some time so you can really figure out what you actually want to change.
    The car you posted looks awesome! However, there is probably a good $10k-$15k of mods done to it. You can achieve a similar look for less but, putting cheap parts on these cars never ends well. For the stance you want you can look into coilovers or a good spring/strut combo. There is a ton of information here on both methods.
    I hope this really long posts helps and if you have any questions feel free to ask, we are generally a nice bunch lol.
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Hawk-Eye Alliance #1856...ssshhh don't tell anyone!
    Mar 2013
    A, A
    Quote Originally Posted by michaelwfox View Post
    Thanks for all the tips. Just an update I got the car yesterday!!!! Runs great. Very fast. Here's some pictures.
    Registered User skinikko's Avatar
    Jul 2012
    Utah
    04 love
    Registered User InsaneManiac's Avatar
    Jun 2012
    San Diego
    Get a compression test on that car as soon as you can. Never know if your motor is on it's way out, that's what happened to my 04. As the guys said, also check to ensure that the car got it's timing belt done, if not then you might be able to negotiate down in price.
    Mar 2013
    A, A
    Just an update. Car is running great did have to replace a sway bar link but that's it.
