Results 1 to 10 of 10
This is a discussion on a/f ratio question....to high or to low within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; my turbo timer af gauge reads its at 3.2 - 3.8 on startup and low to mid 4`s when hot ...
    Dec 2012
    my turbo timer af gauge reads its at 3.2 - 3.8 on startup and low to mid 4`s when hot and running. is this normal?? Thanks for all answers!!
    Nov 2012
    Buffalo
    What kind of turbo timer is it? It should read around 14.7 at idle and cruising, that thing is way off or is not reading in AFR.
    Dec 2012
    it's a apexi ... I'll put a photo on my profile of the timer. Thanks for helping
    Registered User SubiEj255's Avatar
    Jul 2012
    Baltimore
    I don't think it's reading a/f with numbers that low. That's EXTREMELY rich. Your internals would be washed out.
    A car is only as good as its driver
    zax
    zax is offline
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Don't bother with it. It's not a proper wideband Lambda gauge.
    Better question: Why on the earth do you have a Turbo Timer??
    Facebook me here
    Dec 2012
    Oh I don't know .. very new to this . I bought this car with the timer on. I'm not sure if it's right or wrong :O
    Jul 2012
    Baltimore
    It's not necessarily "wrong" but they aren't needed for these cars.
    Texas, United States
    Turbo timer is pointless, and without the propper wideband O2 sensor it wouldn't be able to get accurate AFR readings.. although it doesn't appear to be reading any sort of AFR, so the point is moot.
    Jan 2013
    Flower Mound TX
    I dont think there is a turbo timer that also reads afr.
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by Chinook View Post
    Neither had I, but evidently the apex'i variant has the option to vampire into the O2 sensor output and displays O2 sensor voltage... I'm not sure what the voltage output is at stoich, but it could be what the OP is reading.
    Auto Timer, Silver (with Red LED) APEX Integration
    Facebook me here
