Nope. NORMAL. Subaru didn't add a syncro to reverse.
Either double clutch or do the Subaru Dance(into first/second then reverse)
Posted from a fone.
This is a discussion on hard to shift to R within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; i been noticing that it's hard to shift into r sometimes I have brand new 2013 subaru wrx premium am ...
am i doing something wrong or it just new and it needs to be broken in. ?
Posted from a fone.
desiree
06 impreza wrx tr: cobb stage II - protuned by STi_Mikey!
hawk-eye alliance #11:11 // wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
what do you mean double clutch?
Damn, 5 minutes... that's just insane! You have MUCH more patience than I.
Double-clutch: just as if you are double-clutching.
Press clutch in.
Shift to natural
Release clutch
Press clutch in
Into reverse
That usually solves it for me. Rarely I'll have to blimp the throttle after putting it in natural and releasing the the clutch, rarely... but it happens.
Posted from a fone.
Just a quick word to the wise: If you're having trouble getting into reverse, put the car in first, and let the clutch out ever so barely so the car moves maybe half an inch, it will nearly always go straight into reverse after that.
Cody
Good news, everyone!
Double clutching is usually enough to get into reverse for me, but sometimes that transmission just doesn't want to behave, particularly if the car has been sitting in the cold for a long time.
Isaac -- 2003 WRX sedan Stg II
He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
I'm new to Subaru's but had this same problem with some Saginaw's and Muncie transmission but they both have a non syncronized reverse.. I usually put it in 4th let the clutch out a little just to barely move the car (as said above) thats to get the cluster gear in your trans to line up better with you reverse gearing. It should slide right into place after that.
Hmmm for some reason i don't have this kind of problem... Weird
'13 WR BLUE SEDAN WRX
WORK HARD STAY HUMBLE.
Not getting into reverse on teh first try...... it's what makes a subaru a subaru
I have had the same problem on my 2012 WRX but it went away as the miles piled up.![]()
2005 Subaru Impreza WRX Sti - SOLD
2000 PY Acura Integra Type R 59k miles - EX track warrior/weekend car
2012 WRB Subaru Impreza WRX Sedan - SOLD
2013 WRB Subaru Impreza WRX Hatchback - Factory order placed 8-11-2012 picked up 11-01-12
2013 WRB Subaru Impreza WRX Hatchback - Factory order placed 12-06-12. Yes! Another one
"The Spartans do not ask how many are the enemy, but where are they." - Plutarch
yep. '11 definitely has it.
double clutching always works for me.
Similar problem here. I eventually figured out how to work it![]()
