TMIC
Results 1 to 14 of 14
This is a discussion on TMIC within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Anyone know the orientation of the hose running from the stock TMIC to the throttle body on a 2012 wrx?...
    Registered User anpato's Avatar
    Jun 2012
    TMIC
    2013 SWP WRX Sedan
    Hillside, NJ
    Invidia Catless Downpipe, Custom Short Ram Intake, Self Tuned Using ECU Flash, Romraider and Tactrix
    ClubWRX.net Vendor adam@kronosperformance's Avatar
    Nov 2005
    Princeton, NJ
    I'm not sure what you mean by the orientation...
    Jun 2012
    The position in which the hose is supposed to sit, I pulled my tmic off last night and I cant remember how the hose is supposed to be seated, and the way I have it bolted in now wont match with the support bracket running along the right side.
    2013 SWP WRX Sedan
    Hillside, NJ
    The Member michaelwfox's Avatar
    Nov 2011
    North GA
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Hawk-Eye Alliance #1856...ssshhh don't tell anyone!
    Jan 2012
    New Jersey
    I took mine off to tighten the hose I had a slight leak and read that others have had the same problem. It was a pain to put back on. Look for the flat spot on the hose, I believe i had that closer to the drivers side. I put the throttle body part on first and adjusted the worm clamp, and I sprayed some silicon in the lip of the hose. After that I was able to slide the intercooler back on. It took a little work and was little awkward but went back on properly.
    CFLip2x 2012 WRB WRX Build
    Jun 2012
    Quote Originally Posted by cflip2x View Post
    Yeah i was out there for about 4 hours last night trying to get it in
    2013 SWP WRX Sedan
    Hillside, NJ
    Nov 2011
    North GA
    Quote Originally Posted by anpato View Post
    Sounds like a personal problem
    See the picture posted above.
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Jan 2012
    New Jersey
    He has the 2012 with the oh so awesome plastic TMIC not earlier ones
    Nov 2011
    North GA
    Wouldn't the pipe routing be exactly the same? That picture is from a 2011 WRX
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Jan 2012
    New Jersey
    Nope the 08-up WRX throttle body is off to the right facing more the drivers side.
    [/URL]
    One pic I could find
    Your perspective if you are looking at if from the back you can see the flat spot where the oil is collecting and then the throttle body.
    Jan 2012
    New Jersey
    michaelwfox it Maybe its labeled wrong im not sure but from this pic of a rotated set up from a legacy should be the same for the newer wrx's
    the throttle body is not straight off to the side of the alternator
    Nov 2011
    North GA
    Oh dang, that is a lot different lol. I will keep searching.
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Jun 2012
    2013, but i just put 2012 because theyre both the same.
    2013 SWP WRX Sedan
    Hillside, NJ
    Jun 2012
    Quote Originally Posted by michaelwfox View Post
    Hahaha I set myself up for that one.
    2013 SWP WRX Sedan
    Hillside, NJ
