how much horsepower does an 05 wrx wagon make? - Page 2
Results 16 to 30 of 40
This is a discussion on how much horsepower does an 05 wrx wagon make? within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Look at the last picture. Did someone remove that cap recently? If not, is the cap installed tight? It may ...
    Look at the last picture. Did someone remove that cap recently? If not, is the cap installed tight? It may be leaking.
    - Al Stewart
    Sep 2012
    Bloomsburg, PA
    Quote Originally Posted by Ruh Roh View Post
    looks stock to me. i know the stock 02-03 exhaust was a twin tip and im not sure about the 04-05 i guess they made it a single tip but otherwise looks stock, but i like the seats. they kinda look like rs seats..my friends 05 has seats the same style as my 02 so hmm maybe aftermarket. not sure
    Yeah my fiance was a little confused by the exhaust tip - other subies we see around have a smaller tip, so we weren't sure! and the seats are super nice! uncomfortable when i first got it but good now!
    Sep 2012
    Bloomsburg, PA
    it was removed recently but put back on tightly - but it does look like it is leaking, everytime i look under the hood i see more and more green liquid?
  5. #19
    Quote Originally Posted by 05wrxgirl View Post
    If you see more and more green fluid outside the cooling system there is less and less inside the cooling system. Check those 3 hoses for any signs of a leak (green or white smears, or green or white powder residue). If it's not one of the hoses it could be the cap itself, they have a membrane that can wear sometimes. Check now, see if you can find the remnants of a stream, and if not, wipe the surface clean and check again soon.
    Standing at the nose of the car facing the motor, there is a plastic reservoir of coolant to the right of the radiator at the very front. Make sure the coolant level is adequate (between the max and min lines marked on the side of the reservoir). If you do not have the correct coolant you can simply top up with distilled water (any grocery store, much cheaper, will not affect coolant dilution appreciably unless there is a leak -- and if there is a leak your coolant will get drained and replaced anyway).
    When you are done, do not push the hood shut with your hands. It is aluminium and can bend. Drop it shut from a reasonable height and tell any mechanic etc. to do the same.
    - Al Stewart
  6. #20
    Dec 2011
    Pottstown PA
    Agreed on the stock.
    That axelback portion is stock for the blobeyes. They were similar or near the same as the STI exhausts that year and after. 05 seats started looking more like the racing seats (as an option or with a different package option)
    ohhh well now im informed lol
  7. #21
    Is the white nylon line running along the firewall from the rear upper portion of the intake near the left top of the IC a reference line for a boost gauge? If so at least the line routing, if not the gauge, is not stock I don't think.
    - Al Stewart
  8. #22
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    sorry... didn't read this far into the thread... just posted it after the first one!
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  9. #23
    With that routing? I did not remember that, wow.
    - Al Stewart
  10. #24
    Palmyra, NJ
    That does stand out, doesn't it...Wonder if it was just a poor dealer install job?
  11. #25
    Nov 2006
    Denver Metro Area
    whoops... I only posted after the first post. My apologies dan
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  12. #26
    Oct 2011
    Santa Ana, CA
    Re: how much horsepower does an 05 wrx wagon make?
    Yep was about to say. Factory boost line goes from the bpv. And that's not a 2005 turbo coolant tank. 2005's painted black
    T0rque: nevermind.
    That string bit looks like it's holding the pcv sensor switch thing.
    Posted from a fone.
    Last edited by UEDan; 09-19-2012 at 03:18 AM. Reason: ARGHH Coolant* stupid swype.
  13. #27
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    Quote Originally Posted by UEDan View Post
    Yep was about to say. Factory boost line goes from the bpv. And that's not a 2005 turbo current tank. 2005's painted black
    Posted from a fone.
    my 2005 was the same coolant tank.
    Lead Wrench @ WTF Tuning, LLC
  14. #28
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    that nylon line seems to connects to the High Pressure outlet on the OEM BCS. I don't know if anyone noticed, but the OEM EBCS seems to be absent from the car. Likely the car is wired for an MBC.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  15. #29
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Actually, the 2004 WRXs had the same axlebacks as the bugeyes, but yes, they did change it for 2005, so she has the stock exhaust for her year.
    2007 Outback 3.0R wagon
  16. #30
    Sep 2012
    Bloomsburg, PA
    what does this mean??
