My car runs fine on the original tune without any adjustments. It would run better with adjustments but I am just in limbo before a pro tune anyway.
This is a discussion on Torqued Performance Question from people who have had it done. within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Hey everyone, So I have a quick question regard TP tunes. From my understanding he sends you a base map ...
Hey everyone,
So I have a quick question regard TP tunes. From my understanding he sends you a base map and then adjusts based on 3rd gear pulls.
My question is, how many pulls/logs on average did it take to get the map situated for your car?
Thanks in response too all who respond!
Lead Wrench @ WTF Tuning, LLC
So you saw the improvement and its pretty safe? Sounds great! Thanks for the quick reply!
I suggest purchasing a WBO2 sensor before doing this... you'll get much better results.
Facebook me here
Originally Posted by Mikie13
Forgive the noobness, but does that mean Wide band O2 Sensor? And if so, how many or which one to replace?
Yes, WBO2 = Wideband O2 sensor. You're not replacing anything. You'll be adding a WBO2 sensor, after the turbo hotside and before the rear CatCon. There are really only two acceptable options: AEM UEGO or Innovate LC-1. Though, admittedly, you're better off replacing the downpipe at that point.
Facebook me here
And going stage 2. I see. Yea just wanted a smoother power band a bump in power/tq. Keeping the car basically stock outside of a stage 1 tune. Thanks for the info!
I have a WBO2 sensor.
Not saying zax is wrong, but just from another POV...I dont have a WB02 and went with stage1 from TP. I think he did 2 revisions to the map and everything is running great.
Zach
Teh Intern @ WTF Tuning, LLC
2009 WRB Subaru Wrx Sedan: WTF Tuning Stg2
Stink eye Mob #287
N.E.R.D. #43252003274489856000 (the total number of configurations of the Rubik cube)
"It's not turbo-lag, it's foreplay"
Facebook me here
Sure. You plug your laptop in with the tactrix cable. Open up romreader logger. Chose the parameters he lists in the instructions(note: some don't show up until you are plugged in and car turned on). You then drive around for a little bit to make sure everything is warmed up fully. You then find an empty stretch of flat road and, in 3rd gear, go from 2k-2.5k rpm, click the rear defroster button(turns on the logger) to redline, defroster button again(shuts off and saves). Do that a few times. Make sure there is no knock(there are two types, they list in the instructions). Also, its good to do a learning view(kinda like a picture of your ecu), I forget exactly where you can find that program.
Rear the tutorials on ecuflash and romraider before hand so you know what you're doing. Make sure you save your stock tune in a safe place. Make sure your battery will not die on either your car or laptop while flashing...if that happens you are f***ed.
Anything else I forgot boys?
Zach
Stink eye Mob #287
- William
You used to have to select an option in the logger to be able to toggle with the defrost.
Stop after your first log and look at it to make sure you are getting data.
He will send info on what/how to log, but here is a good background read:
Datalogging with Romraider:
i didnt have to, maybe its an older version. I checked to see if it was receiving by checking off the RPMs monitor and just revved a bit.
Zach
Stink eye Mob #287
