Results 1 to 6 of 6
This is a discussion on Save it or sell it within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; So as my profile stated I recently bought a 2002 Subaru impreza Wrx. The car is beautiful but mechanically it ...
    Sep 2012
    Bellmore, new York
    Save it or sell it
    So as my profile stated I recently bought a 2002 Subaru impreza Wrx. The car is beautiful but mechanically it needs work. So when I bought it I changed the brake pads , ball joints. The car also has had a remanufactured computer installed, new maf sensor, timing belt, water pump, accessory belt, spark plugs , complete tuneup. Overall I've spent like 2k in maintenance, however after the last part was installed the car is smoking white smoke. My mechanic told me he thinks the valve seals are done on the car. However I have been reading several forums saying that if the turbo seals go bad this will blow blueish white smoke. Now here's the thing drove the car and noticed smoke coming out of the hood scoop , popped the hood and noticed the oil supply to the turbo was dripping onto to the turbo and causing the smoke. To me this seems like it could have caused the turbo or seals to go and cause the smoke, assuming the turbo isn't being properly lubricated. Does this seem like a possibility? Also is there a Way to check the valve seals without ripping the motor apart ? Also the security light constantly flashes a single time repeatedly and the car won't start. You can hear w everything cycle electronically but the motor doesn't turn over. Any ideas? One last thing noticed oil spots on the ground in front of where the turbo is, dont know what that's about , also is the oil in the motor the supply for the turbo, and would putting Lucas oil in the engine oil stop the turbo seals from smoking of they're bad? Thanks to alll who respond and sorry for the long post
    Registered User scarmack's Avatar
    Apr 2012
    Sharpsville, PA
    sell
    2012 Limited Black Pearl WRX
    My Build to Destruction
    Registered User Acrdys's Avatar
    Jun 2007
    Lemore
    Count up how much you would lose from selling it and compare it to the benefit of getting it to run right. But it sounds like a pain and unless you want to put money down in upgrade/replacement parts/labor I would sell.
    Hawk-Eye Alliance#8089
    MODS LIST
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    The motor oil is also the lubrication for the turbo. Bad seals of any kind can NOT be repaired with "special" oils or additives. Never have I seen anything that actually worked. For the valves the engine valve covers would have to be removed at the very least. Of course those are not easy to get to... Selling is probably your best bet. See what else the marked has available and how soon would you really want it. I usually take my time there's always a good deal coming up sometime when.
    Registered User kevo0311's Avatar
    Dec 2011
    so cal
    Re: Save it or sell it
    Funny thing about subies is if lasts past 80k your good once you see smoke bye bye car.
    Sell it you can unless your rich
    Sent from my ADR6350 using Tapatalk 2
    Apr 2007
    8000' up in Colorado
    Quote Originally Posted by 02wrxguy View Post
    What part was installed?
    If the turbo wasn't getting oil, then it's entirely possible it's toast. How long do you think it was without oil? The dripping on the turbo wouldn't cause it to fail, but it would definitely cause smoke because they're extremely hot and the oil would be burning. Is the turbo making any unusual noises, or does it sound ok? Have you checked for shaft play?
    Scott
