gear engagement
Results 1 to 15 of 27
This is a discussion on gear engagement within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Hey guys. '12 Rex that I've had for about 1600 miles now. Just noticing that after the car sits for ...
    Registered User rikkyb30's Avatar
    Apr 2012
    Southeastern CT
    gear engagement
    Hey guys. '12 Rex that I've had for about 1600 miles now. Just noticing that after the car sits for a few hours or more, I hear this loud sound after I'm in first and rolling that sounds like a gear engaging. Already in first and starting to roll away w foot off the clutch pedal when I hear the sound usually. Not sure what to make of it so gonna get it checked out but wanted to see if I could narrow it down any more before heading to the dealership.
    Thoughts?
    2012 WR Blue WRX
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Does it happen after you reverse first?
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Apr 2012
    Southeastern CT
    YES! Trying to think now if it also happens if I just roll out forward, no reverse. But Im not sure it does.
    2012 WR Blue WRX
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    is it a whine or a grinding sound? Or does it sound more like straight cut gears meshing/whine?
    Reason I ask is that these transaxles are notoriously noisy.. it might be normal. Are you having any issues getting into/out of gear? Is it in every gear or just the first few?
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
    Apr 2012
    Southeastern CT
    It's more of a loud, short meshing thud. Only happens in first after the car has been parked for a bit. So for instance if I get into my car after a day at work, it does it. But when I reach the stop sign 15 feet away, doesn't do it again. No issues getting into or out of first, other than the general slop in the shifter. Reverse can be a pain sometimes but I hear thats normal.
    2012 WR Blue WRX
    Oct 2009
    hmm.. interesting. I'd take that in and have the dealer look it over. Esp since its so new and you did pay for a warranty. Make sure they drive it before telling you they're normally noisy.. which they can be.. but they normally dont make thud noises. Is this under hard acceleration or gently rolling off?
    SWP 2013 FRS
    SUCH IS MANGO!
    Apr 2012
    Southeastern CT
    Gently rolling off. It's weird sounds as if its locking the gear in late, but I am already rolling off so it should be engaged.
    2012 WR Blue WRX
    Jul 2010
    Cincinnati
    I believe it might be the "hill assist" sound that people have talked about, mine makes a light "engagement" sound about 5 feet after starting forward. Could that be what you are hearing?
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
    Apr 2012
    Southeastern CT
    Yeah exactly, maybe that is it. I definitely notice it as I am going downhill the most (park my car on the downramp at work). Is that normal or should it not be doing that donwhill or on flat?
    2012 WR Blue WRX
    KHP
    KHP is offline
    Registered User KHP's Avatar
    Oct 2010
    Reno, NV
    From your description I believe that's the anti-lock brake/Hill Assist/Electronic Brake Force Distribution/Brake assist motor doing a self test cycle. Completely normal as my car and my friends fiancee's Impreza does the same.
    2011 WRX Limited Spark Silver (5 Door)
    Apr 2012
    Southeastern CT
    Hmmm, interesting. That would explain the fact that it only does it after cold starts. Ive never owned a car w ABS before. So what exactly is it doing during this cycle?
    2012 WR Blue WRX
    KHP
    KHP is offline
    Oct 2010
    Reno, NV
    Quote Originally Posted by rikkyb30 View Post
    I'm not sure about the internal workings of the module itself, but its probably testing whether the motor, valves, solenoids are operational. Otherwise if it detects a failure you'll most likely get the ABS light on your dash.
    Registered User peekeesh's Avatar
    Mar 2012
    i hear that loud 'THUD' sound too. It happens exactly as the OP described it.
    Aug 2010
    Yonkers/NYC
    Sounds like the hill assist disengaging.
    T0ny
    2011 WRX
    2012 FXT
    Apr 2012
    Northern California
    It happens in my 09' too. Scared me at first, I thought I ran over a cat or something.
