This is a discussion on 2012 wrx stage 2 performance? within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; To the OP, you don't need the catback to go Stage 2. Just a thought, if your on a budget. ...
To the OP, you don't need the catback to go Stage 2. Just a thought, if your on a budget. I plan to do the DP and tune to get there on the stock catback. Maybe down the line, I'd go with a new catback, but don't want to add much more noise/drone; especially for slow traffic driving.
I have a low Reynolds number
TP Stage 1 - 2012 WRX Premium 5-Door SWP
Pics!
- William
I know I could prob find this by doing a search but I stumbled upon this thread and figured Id ask, Is there any benefit to adding an intake to the car, stage 1 or 2? or is it just a noise maker?
With a base map like Cobb, you don't see much in the terms of power gains, but you should see a little better response. With a custom tune, you can really take advantage of the better airflow.Originally Posted by Kam91
Hey guys---just got my few days Cobb AP running on stage 1 map. Feels a bit smoother after 3000
Rpm. Stage 2 is want I want to go next. Can't decide if I should go cai AEM or Cobb intake with DP catted. Any benefits between the two?
2012 WRX PPB sedan
Foglights installed, Arm-rest extension installed. Upgrades: Eiback F/R sway bar, Kartboy endlinks F/R, Cusco lower chassis brace, COBB AP stage 1 map.
Both intakes will give you the pshsst sound but neither will give you much in actual gains. Catted or catless downpipes will net you much better gains even with a stock intake.
Sent from my Galaxy S3 using Tapatalk 2
The cobb is a short intake that will still be well inside the engine bay so if you go that route the intake box will be a wise investment to help separate engine heat. I don't know much about the AEM intake, but if it is a true cold air intake it will pull air from outside the engine bay (down near the wheelwell), and will probably do a "better" job pulling in cold air. Ultimately it will really be the restriction of the stock intake as far as ability to pull in enough air that will ever be a limiting factor (which won't be until you are way above stock power levels). At stage 1 it won't make a big difference in power but will sound cool
I plan in AEM CAI and DP catted with pro tune in my next mods this summer. Thanks guys!
2012 WRX PPB sedan
