stock intake filter replacement - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
This is a discussion on stock intake filter replacement within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; It won't affect your warranty to use different brake fluid. As posted above, it improves the feel of the brakes ...
    Apr 2007
    8000' up in Colorado
    As posted above, it improves the feel of the brakes under hard use, and also greatly reduces fade since it doesn't boil as easily.
    That being said, I still got a spongy pedal at one point on my latest track day. It only happened once in my 2nd session on the track, but never again. Weird.
    Scott
    Registered N00b impretzel's Avatar
    Nov 2010
    SoCal 626
    The most common cause of warped rotors isn't from driving them really hard. It's from getting water on them when they're hot.
    Actually, that is the ONLY cause to warping rotors. Riding the brakes, or frequently stopping hard causes the rotors to warp and can be repaired by resurfacing unless the damage is too severe.
    Getting the brakes wet while very hot (braking through a puddle) causes "heat spots" on your rotor which are visible (they look like dots usually in a circle). Rotors with heat spots can not be repaired and at that point are ruined.
    Warped rotors = left to right shaking while braking
    Rotors with heat spots = inconsistent/not smooth braking. As if the front wheels were oval or you jab the brake pedal very quickly. No steering wheel vibration.
    But to stay on topic, id say stick with the stock aircleaner until dirty. Then go aftermarket with a company of your choice.
    '12 STi stage 2
    Origin GT = impretzel
    Bf4
    -JJ
