Top strut nut
Results 1 to 8 of 8
This is a discussion on Top strut nut within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Hey guys, does anyone know how to torque the very top strut bolt? I can't get the shaft to stop ...
    Nov 2011
    Auckland nz
    Top strut nut
    Hey guys, does anyone know how to torque the very top strut bolt? I can't get the shaft to stop spinning??? I have HKS hiper Ds
    Oct 2005
    Late Devonian
    Install them in the car, then try to torque it.
    Captain James of the SS Impreza has gone down with the ship Drews's Avatar
    Aug 2008
    Davey Jones Locker
    Or use a strap wrench.
    Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
    Stable: 2014 Hyundai Veloster Turbo (Matte Grey), 06 LGT, 98 RS, 16 Crosstrek
    Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
    Never argue with idiots. They'll drag you to their level and beat you with experience.
    Registered User Wussola's Avatar
    Sep 2011
    Portland, ME
    I just installed Epic springs a couple days ago ... I also had this issue. Are you trying to torque them to spec .. or just tighten them? What i did was take my 14mm socket and used a vice grip to hold onto it. Put it on the top hat bolt and then I put the allen wrench through the middle of the socket and tighten it that way. It worked well!
    2011 Subaru Impreza WRX (Premium) | EFI Logics Tuned Stage 3 | Cobb SF CAI | Invidia EL Race Header | Cobb Catted Downpipe | Borla CBE | PW TMIC | Grimmspeed EBCS | Grimmspeed AOS | DW 65C Fuel Pump | Grimmspeed Light Weight Pulley | SPT Short Shifter | JNA Front Lip | EPIC Performance Springs | SMY Cluster w/ Boost & Oil Pressure
    Oct 2005
    Late Devonian
    Quote Originally Posted by Wussola View Post
    I ended up doing something similar last time. Usually just putting them in the car and putting it back on the ground will do it though. Once you get them fairly tight you should be able to use a torque wrench and have the shaft stay put.
            MainFrame's Avatar
    Austin, TX
    I would always just get a friend to hold the shaft () while I would turn the nut.. wasn't too hard.
    Nov 2011
    Auckland nz
    So iv managed to torque the top bolts to the correct specs. Iv replaced the steering rack bushes also but I'm still getting a slight 'knocking' noise. Iv re-used the The standard top hats, would the next bet be to replace them???
    Also, with the struts out of the car the front top hats should be able to spin freely should the rears be able to do the same??
    Oct 2005
    Late Devonian
    The rears don't need to spin.
    I get a knocking - it is due to my wing on my wagon flexing that panel.
