idle problems...
Results 1 to 7 of 7
This is a discussion on idle problems... within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; i have a v2 wrx has divorced down pipe pod chipped computer ect.. had a rain storm the other day ...
    Mar 2012
    new zealand
    idle problems...
    i have a v2 wrx has divorced down pipe pod chipped computer ect.. had a rain storm the other day now something just is not rite.. it normaly idles at 1500 rpm due to chip but all of a sudden idle drops and car runs rough then 30min later it will run fine again!! HELP!!
            MainFrame's Avatar
    Austin, TX
    I would check for CEL codes first.. Do you have any way of data logging the car?
    Mar 2012
    new zealand
    no no way to... i was told it may be the air flow sensor apparently subarus dont like the ones with oil in them (was told this after) because the oil gets on the sensor and buggers them. what do you think?
    This is not untrue and it will not hurt to clean the sensor. To do so, treat it like delicate electronics, not a car part. Use electronics cleaner only and clean both the visible probe, which I think measures temperature, and the sensor that is located at the inner base of the stalk. Be very gentle and only use the correct cleaner.
    Also clean your filter and when you re-oil it, use as little as possible. If there is residue on the inside of the tubing between the sensor and the intake, clean that too.
    I'd suspect water somewhere (else?) though.
    Mar 2012
    new zealand
    yeah i think there may be water somewhere else too ..i have gone all out and brought a new afm and a foam somota pod so i will let you know how it goes.fingers crossed
    Mar 2012
    new zealand
    hey!! thanks for all of your help it turned out it was the afm!! put the new one on and now its good as gold
    Great to hear, congrats.
