what else can i do to my engine??? 2005 WRX - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 47
This is a discussion on what else can i do to my engine??? 2005 WRX within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Originally Posted by Champ_WRX_77 thanks.. when i get my down pipe and uppipe do i need to get it tuned ...
    Quote Originally Posted by Champ_WRX_77
    thanks.. when i get my down pipe and uppipe do i need to get it tuned after i get the pipes put on or can it wait till after i get my fuel injectors?
    You're fine with the Cobb AP.
    Your other mods are useless / draining power with that map, but yeah.
    Resident Tuner @ WTF Tuning
    Feb 2012
    Two up Two down.... VA.. U know what it is
    What should i do to reduce the power being drained? and all i am getting is negative feedback with the cobb AP... really that big of a difference between the Cobb AP any other pro tune?
    Registered User GarrettKoonsman's Avatar
    Apr 2009
    CO
    Quote Originally Posted by Champ_WRX_77 View Post
    get rid of the front mount until you have a turbo that needs it, get rid of the BOV for a BPV.
    And a protune will be much better than a cobb tune as protunes are created for your specific car and cobb tunes are generic.
    2003 Midnight Black Pearl WRX Sedan
    200.7 AWHP Protuned Stage 2 at 5400ft above sea level
    Bugeye Mafia Member #225
    Mods
    Pics
  6. #19
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    Quote Originally Posted by T0rque View Post
    well you didnt list the single biggest power gain which is removing the catalytic converter in your up pipe for a catless version.The other is that the HKS Downpipe is a piece of junk unless your running the newest version. Get an up pipe and down pipe.
    Since your only stage 2 and your going to change those pipes I suggest a blouch turbo charger, larger injectors, turbo inlet and a bigger fuel pump.
    Ok thanks for the help.. Just talked to a guy at all aspects he is saying to do my uppipe first to basically save my turbo... ideas?
    Lead Wrench @ WTF Tuning, LLC
  7. #20
    The FMIC is not ideal for smaller turbos, since spool and throttle response are the big benefit.
    The BOV is not ideal for MAF-based cars, since it vents metered air (instead of recirculating it), causing a slight rich condition.
    The Cobb AP is a great medium for tuning. You can get a similar tune via OpenECU, which is cheaper (since you don't have the overhead for a device that typically sits in a box).
  8. #21
    Feb 2012
    ok all good advice thanks to all again for helping a new guy out... i think ill start out with the uppipe, down pipe, and injectors... what size fuel injectors would be best? and what difference does it make in the size?
  9. #22
    What are your overall plans? I wouldn't bother with injectors on the TD04. If you see a turbo swap in your future (which, with a budget of $1500, you should be able to do), I'd go with the 650s I recommended earlier.
  10. #23
    Feb 2012
    ok so if im going to go ahead n do the downpipe, uppipe, injectors, and pro tune should i just go ahead and get an upgraded turbo? Ill bite the bullet in throw down the extra cash... basically i just want a strong reliable car that i can drive daily without to much hassle
  11. #24
    If you're going to do injectors (which should be fed by an upgraded fuel pump), buy a Blouch 16G as well. It will make the uppipe install easier, and you're there already.
    Only thing not in my list is aftermarket boost control; talk to AAM to see if they prefer an MBC or BCS (both is ideal, but they may not feel comfortable tuning that).
  12. #25
    Feb 2012
    Awesome thanks man u been a big help so heres what i am getting out of all this for what i need
    -uppipe
    -downpipe
    -fuel pump
    -fuel injectors
    -16 g blouch turbo
  13. #26
    Feb 2012
    The car has a catless downpipe already, full turbo back exhaust ." - my cars previous owner
  14. #27
    Feb 2012
    So I jus need a
    -fuel pump
    -turbo
    -injectors
    -uppipe
    -pro tune
  15. #28
    Dec 2004
    Medford, Oregon
    no, your up pipe is NOT catless unless he replaced it also, a full turbo back does not mean cat less up pipe
  16. #29
    Feb 2012
    Ok so that means I just need the uppipe though right??
  17. #30
    Dec 2004
    Medford, Oregon
    can you post a pic of your downpipe where it bolts to the turbo? You have an HKS which is probably an old school non bell mouth type down pipe, that is why we have recommended a new downpipe. here is a few pics of non bell mouth vs bell mouth. Bell mouth is needed for turbo up grades.
ID:	102827Click image for larger version.
