Results 1 to 15 of 22
This is a discussion on Complete newb! within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Hi everyone! I bought an 02 WRX this past saturday and currently I have gotten a new timing belt change ...
    Dec 2011
    Complete newb!
    Hi everyone!
    I bought an 02 WRX this past saturday and currently I have gotten a new timing belt change as well as water pump, all the other belts changed, oil change, new spark plugs, and thermostat. I'm really excited about this car and I upgraded from a 95 civic hatch to this amazing car! And I'm completely new to subarus and the turbo and everything! So I'm going to need a lot of help!
    As for now I want to keep it mostly stock bc I am a full time student. However I read that the cat in the uppipe can break and damage the turbo. I would def want to invest in a new uppipe but I live in ca and the smog laws are very difficult. So my question is, will gutting out the cat in the uppipe ruin my chances of passing smog legally or will I have to buy another cat and put it somewhere else? Right now this is My main concern as this is going to be my daily and I spent more money than I ever had to buy this car. So I need advice from my Cali people! And I want to keep it smog legit.. At least for now lol
    Registered User Monk_Knight's Avatar
    Aug 2010
    Colorado
    It's definitely a reason they could use to fail you... whether or not they would catch it would be the bigger question. I'd say pass smog then replace it and save your stock one to put back on when you have to pass smog again.
    Dec 2011
    Quote Originally Posted by Monk_Knight View Post
    Ya I could do that but I heard it was a pain in the butt haha.. Do u have a stock one on urs? And if not do u pass smog without having to change it?
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Gut the stock cat. Take the up pipe off, then take a screw driver, then dremel to the inside, breaking apart all of the catalyst element. then dremel it smooth, then reinstall it. Cheaper than an uppipe, will pass the visual smog inspections, and you'll get a bit of a power gain.
    Administrator TheJ's Avatar
    Dirty South
    Yep.
    Welcome to Club!
    -The J
    New Members, CLICK & BOOKMARK these links:
    Aug 2010
    Colorado
    Quote Originally Posted by lendo_21 View Post
    I'm only in Tahoe for school, my car is registered in Colorado and they don't test emissions back home. So it's a non-issue for me.
    Jul 2010
    Cincinnati
    Legally you would not pass, but even with that converter non-functional, you should still run clean enough to pass a smog test.
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
    Dec 2011
    haha lucky!
    Quote Originally Posted by jd92677 View Post
    Ok cool, so if I gut it I can pass the visual and the emission part of it..
    Another question, If I gut out the cat on the up pipe will the sensor give me a CEL? and If it does how can i avoid that or delete the code or whatever so I don't get into probs with the smog?
    It will trip a CEL, but that's disabled by replacing the EGT sensor with a resistor.
    Sent from my Droid using Tapatalk
    Nov 2006
    Denver Metro Area
    Yup... a 2.2k ohm resistor if I remember correctly. Like 80 cents at radioshack.
    1/2W, I believe
    Nov 2006
    Denver Metro Area
    2.2k Ohm. I win
    2.2K Ohm Resistor Mod
    edit... googled 2.2k ohm resistors, and found that they were all 1/2 watt. Alright. We both win.
    (but 1/2 watt doesn't = 2.2k ohm. OP... make sure you get a 2.2k ohm, 1/2 watt resistor)
    Jul 2010
    Cincinnati
    But if you're gutting the cat, you can leave the EGT in, can't you? Therefore it wouldn't throw a CEL
    Stink eye mob #727
    Nov 2006
    Denver Metro Area
    You're correct. My apologies. But the EGT sensor is only there for the cat... so might as well remove it, plug the hole with a bung plug, and not have anything in the pathway of the exhaust.
    2.2k Ohm. I win
    Someone PMed me a while back asking whether to get ¼W or ½W versions, which is the only reason I specified. Maybe they only make ½W ones...
    It may still throw the CEL, not sure.
    Either way, remove the sensor.
