Results 1 to 6 of 6
This is a discussion on How much does it cost to lower a Subaru WRX 2008-2011? within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Im planning to get a 2011/2012 wrx in the fall of 2012... I was wondering how much it would cost.. ...
    Nov 2011
    Im planning to get a 2011/2012 wrx in the fall of 2012... I was wondering how much it would cost.. I'd like to know the materials I would need and the approx prices for it.. so I can start saving up for it. Dont know much about cars just yet obviously.. thanks
    Toboggan T0rque's Avatar
    Dec 2004
    Your Mommas
    Doing it right you could be in it about 800-1500 depending on the brands you go with. Your going to need struts/springs and if you want coilovers your in the 1100-4800 price range.
    Lead Wrench @ WTF Tuning, LLC
    Prices will vary depending on what you want.
    Minimum: springs / alignment. The struts will likely wear out faster, so expect to do them down the road, at which point, you'll need another alignment; the more performance-oriented the springs, the faster your struts will need replacement.
    Moderate: springs / struts / alignment. This would be the best route to take with cost / ride quality in mind.
    DD Performance: struts / springs / camber plates (F) / tophats (R) / camber bolts (R) / alignment. This will give you the best setup for street driving, and some motorsport use, but raises the budget. The camber plates / bolts will allow for more adjustability in your alignment.
    Looks, performance be damned: "cheap" coilovers / alignment. You can slam the car and adjust ride height at will, with each adjustment requiring a new alignment. The cheap coilovers will not offer a less than ideal ride comfort, and the quality of parts will not meet the performance of a quality strut / spring setup. Coilovers may or may not come with camber plates / tophats, so they may be needed as well.
    Motorsport performance: $2K+ coilovers / alignment. While not offering as harsh a ride as the cheap coilovers, they will not meet the comfort of a quality strut / spring setup for DD vehicles. They will likely outperform a quality strut / spring setup in motorsport settings, when paired with appropriate other parts (e.g., tires, brakes, etc.). Coilovers may or may not come with camber plates / tophats, so they may be needed as well.
    Registered User twister8008's Avatar
    Aug 2011
    ND
    Why? It is perfect the way it is. Large speed bumps and curbs are already higher
    Sent from my ADR6350 using Tapatalk
    Yellow lights mean go faster!!!
    Apr 2007
    8000' up in Colorado
    ^^^ this
    Before you decide what you're going to change on the car, it would be smart to actually drive it for a while.
    Scott
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    Greg
    www.modmeets.com
    ProTuned Stage 3 '11 WRX Ltd HB (SWP) ~ 342 awhp 399 ft-lb tq on E85
    Mods Blog Post
    Friends don't let friends drive Mitsubishis.
