Welcome. If you're sure the master is OK then the slave is left I suppose. Also look for leakage between them, including on the cabin side of the firewall along the pedal body.
This is a discussion on plus one more nooby within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; hi all, im brand new to the subaru world but heard its a good one iv recently been given a ...
hi all, im brand new to the subaru worldbut heard its a good one
iv recently been given a 97 wrx wagon by my flatmate who has moved away "not a bad deal" but, im having ploblems with the clutch pedal sticking! iv changed the fluid cleaned out the lines and had a new seal kit put in the master cylinder but it still seems to be doing it. iv checked for leaks at the slave cylinder but all seems well.
any advice would be great![]()
Welcome
Contributing unsolicited, worthless opinions since 9/10...
The project I spend all my money on.... <---- Click it
Welcome![]()
welcome
welcome buddy
"exhaust gasses go into the turbocharger and spin it, witchcraft happens, and you go faster" -jeremy clarkson
Hi all, thanks for the welcome and advice
Iv fitted a new line from the master to the slave and with the other things iv done, it does feel alot better. But been driving around today and the pedal got stuck half way down on 2 occasions (normal driving nothing hard) not sure if this will make sense, it seems to happen when braking reasonably hard to a stop clutching into neutral then go to select 1st and the pedal is half way down.
Could it be something to do with the slave not holding pressure??
Simota air flow filter or just get another stock one, any thoughts??![]()
