what heat shield are you talking about? If you are talking about the downpipe then no it well not go back on anyway.
This is a discussion on Question about the heat shield on the exhaust within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Does the heat shield need to be put back on after a aftermarket exhaust gets put on?...
yeah thats what i meant sorry
If you're talking about the one under the mid pipe (under the car, not the turbo heat shield), you can remove that one, too.
Greg
www.modmeets.com
ProTuned Stage 3 '11 WRX Ltd HB (SWP) ~ 342 awhp 399 ft-lb tq on E85
Mods Blog Post
Friends don't let friends drive Mitsubishis.
yeah to everything... the less stuff i have to put back on the better
One reason the one under the midpipe is there is to "prevent some heat transfer into the cabin floor." But primarily, it seems to be there just to block access, rub on your CBE, and carve skin off the back of your hands during installs. :-)
Greg
www.modmeets.com
Mods Blog Post
Do you need to put it back on? No
Will you experience i/c heat soak without a turbo heat shield? Yes
It's kind of all up to you if you want one of not. Are you willing to possibly experience heat soak? You can cut your stock one to fit aftermarket down pipes (pretty easy to do), or you could buy an aftermarket one. Cobb and Grimmspeed both make one. Either way, it's all up to you, but once again, you do not need one.
Edit: My post is only referring to the turbo heat shield...if you're talking about the midpipe one, don't even worry about it.
--Anthony 2011 DGM WRX stg2+sf intake + custom front end deer mod!
Official Subie owner as of 01/10/11![]()
Stink Eye Mob #87
Bye bye Bimmer![]()
Hellooo '11 REX
