Did you just get fuel too? If so, tighten the fuel cap. If not, have the CEL code read and post the code here so someone can help you.
This is a discussion on Just my luck, within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; I took my 03 WRX to have the oil changed and about an hour later my Check Engine light came ...
I took my 03 WRX to have the oil changed and about an hour later my Check Engine light came on and stayed. Should I be concerned? Also I opted for the 5w40 Syn. and the car actually seem to feel smoother if that sounds possible. Thanks for any info...
Bobby
Thanks for the tip I'll try those.
