Tastes vary. Go to a meet and listen. My fav is a Stromung but I like money more than I like mufflers so I kept the stock muffler on the car.
On your car, sure; I'd never run one on mine though. I doubt it filters better than a paper OEM filter, and I strongly dislike the oiling process and the potential to mess up the MAF and/or allow more silicon than absolutely necessary into the motor. I therefore use the correct filter specified, not a fancy oiled filter. If I owned your car, I'd still use the correct paper filter specified...Also is it ok to run the K&N filter in it.
There are several oil threads, look around, but have an eye out for hype and unsubstantiated claims. Look in the owner's manual for the oil specs, and pick an oil that meets those specs exactly. I happen to use Shell 5W-40 but there are numerous other choices.One last one what type of oil should I run in it, Synthetic? Thanks for any info and help.
Bobby![]()
LinkBack URL
About LinkBacks
You are quite welcome - enjoy the time here.
