I'm New with no boost !
Results 1 to 15 of 26
This is a discussion on I'm New with no boost ! within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Hey guys, This is my first Subaru and I'm new to the forum. I got a 2005 wrx with about ...
    Sep 2011
    Brooklyn
    Red face I'm New with no boost !
    Hey guys,
    I got a 2005 wrx with about 100k on it, everything is stock.
    the guage on top by the steering just goes up to is it .6 or 6 and thats it.
    it drives like a normal car no real ump you know but then again I never had a turbo charged car but shouldn't the boost be noticeable !
    Another thing is the gas mileage is really bad. I filled up and drove about 50 miles and its already on 3/4 tank is that normal for these cars ?
    any feed back that can help me fix this would be greatly appreciated.
    Thanks in advance
    Nic
    Sep 2011
    Hey im new too!! lol.
    Alright man first off let me just say that i am in no way a WRX guru i recently purchased my 2011 WRX a week ago and it is also my first forced induction car. With that said i have been on the on/off track racing scene for a while and have owned and tweeked several N/A performance cars prior to my WRX. So now that you know the background i am working with I will attempt to ASSIST you with your possible problem. The number one thing i can say is that you should definitely feel at least feel the car pull harder when the turbo spools up. The WRX you own does not have the same turbo as my 2011 so a comparison would not be accurate since my car has a 2.5L engine and a VF52 turbo which as far as I know makes abt 13.5 lbs of boost stock. When I push the gas to WOT there is about a 1 second period of turbo lag and than there is no doubt that the turbo has spooled and is at max boost. If im not mistaken your subaru is equipped with a 2.0 liter engine and i believe it is called a TD04 turbo that should make about 13.5 lbs of boost as well. As for the gas problem if you really used a quarter tank in 50 miles that is not normal at all. But remember dont just assume you guage is accurate maybe look up how many gallons your tank holds, fill it up and divide the miles you drove by how many gallons you really used to see if its a faulty guage. or avoid it all and take it to a subaru certified mechanic and have them look it over for you. They will charge a small fee but it is worth it so you know what you are getting yourself into man. hopefully this is helpfull.
    P.S. if anyone sees any incorrect info in my post feel free to correct me as I am a new guy on here, thanks yew
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Welcome! Congrats on the purchase!
    First: Any modifications to the car?
    Second: What gear are you measuring your boost in?
    Third: Where are you located?
    Fourth: How are you measuring your boost? Is it the stock gauge?
    Fifth: Are there any Check Engine Lights? Is your Cruise Control light blinking?
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Sep 2011
    Brooklyn
    Hey Guys,
    thanks for all the input !
    Here is some more details. I should have mentioned it is an Automatic as well.
    I had a guy check it out beore i got it but no compression + leakdown tests were done. There were two code one for low voltage and one for the abs sensor. it had a minor accident in 2006 in Florida , you can see where in that they just knocked the dents back out. I did a Carfax which showed the accident.
    i bought it from a guy who has a dealer license and buys out of state cars and sells them here in New York.
    He doesn't have have any info about maintenace or service.
    Only got the car last thursday.
    Car is Stock.
    Its an Auto.
    I am looking at the stock gauge and it only goes up to .6 i think it is. (i will double check. i sent the car to detail, it was in a real mess). Its like a regular car , no kick from the Turbo.
    My brothers Minivan has more pull that me right now ! Thats just not right !
    I'm in NYC
    No Check Engine Light.
    No Blinking Lights.
    Its averaging about 14 miles per gallon but i was trying to see it the turbo would kick in since i had it. I filled it up with 93 octane from a Mobil 1
    Thanks again for all your responses !
    Registered User GarrettKoonsman's Avatar
    Apr 2009
    CO
    check your boost and vacuum lines
    2003 Midnight Black Pearl WRX Sedan
    200.7 AWHP Protuned Stage 2 at 5400ft above sea level
    Bugeye Mafia Member #225
    Mods
    Pics
    Sep 2011
    Brooklyn
    Ok this is what I got with learning to read the boost gauge.
    On N 500 rpm : -.07
    On D 500 rpm : -.06
    2000 rpm : 0.0
    2500 rpm : 0.02
    3500 rpm : 0.05
    I check this on the Belt pkwy but there was too much traffic.
    So it looks like the turbo is working but the boost is building real slow which would be caused by vacuum leaks right ?
    Let me know what you guys think.
    Thanks
    Nic
    Apr 2009
    CO
    Well what gear is that in? That is 7 lbs of boost by 3500 rpm.
    Mods
    Pics
    Oct 2005
    Late Devonian
    That looks like wastegate spring pressure only. The turbo is probably fine and the issue is the boost control system. Make sure it is hooked up like so and all the hoses are good, test the solenoid if that doesn't work.
    Registered User NitroNate's Avatar
    Nov 2007
    San Antonio, TX
    gas mileage on an AWD turbo car is never going to be that great unless you drive it like a grandma, and even then you can't expect too much.
    2004 Subaru Impreza WRX 2.0L
    2011 Ford Mustang Shelby GT500 5.4L
    2005 Toyota Solara SE 2.4L
    Sep 2011
    Brooklyn
    Quote Originally Posted by GarrettKoonsman View Post
    I think it was already in 4th
    Sep 2011
    Brooklyn
    Thanks mycologist ! I will check this over the weekend !
    Registered User kcwrxfan's Avatar
    Jun 2011
    Shawnee, Kansas, United States
    Quote Originally Posted by NitroNate View Post
    i don't drive mine anywhere near a "Grandma" style and avg 22mpg but 14 seems low for the car.
    2011 WRX Limited Stage 3 TP Stinkeye Mob #93
    Apr 2009
    CO
    Quote Originally Posted by Rrzzar View Post
    at what speed?
    Mods
    Pics
    Sep 2011
    Brooklyn
    at what speed?
    about 50-60 mph
    Apr 2009
    CO
    ok. Ya check all your lines as posted. Honestly I would just go pick up some vacuum hose and replace all of the lines except the one with the pill in it. Its a pretty quick thing to do and will eliminate any sneaky leaks. You need either 5/16" id or 3.5mm id
    Mods
    Pics
