Results 1 to 9 of 9
This is a discussion on SPT short throw and bushings - loose/sloppy in gear? within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Hey guys, I just got the SPT short throw and bushing installed on my 2011 WRX. Now the shifter has ...
    Jul 2011
    Hey guys, I just got the SPT short throw and bushing installed on my 2011 WRX. Now the shifter has a lot of play and side to side movement in all gears. Is that normal? It doesn't seem right, but I'm not savvy about much anything with cars.
    Here's what happens: ‪2011 WRX SPT short throw‬‏ - YouTube
    Thanks in advance for any help.
    Eric B.
    Negative pantsy rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    You had it installed or you did it yourself?
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    The Big 2011/2012 Mod Thread
    "Just Leave me alone. I know what I'm doing"-
    Kimi Räikkönen
    Jul 2011
    Had it installed at dealership where I bought the car. In hindsight I should have asked them before driving off with it, but I was excited to try it out and it didn't really sink in until a day later. Thanks.
    Aug 2010
    Yonkers/NYC
    That does not look right.I don't have the SPT shifter.I have the kartboy shifter & bushings & its nothing like that,very firm.
    I think you should take it back.Maybe they didn't torque something to spec.My guess would be that its the either the lever pivot or the shifter U-joint.Since th SPT shifter comes with the linkages they would have taken the entire assembly apart.
    If you look in the thread in my sig,post No 3., you can see what I'm talking about are the parts where bushings A & C would go.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    Kimi Räikkönen
    The Fruit mangostick's Avatar
    Oct 2009
    the ghettooooo
    yeah that is NOT right.. my factory equipment standard shifter in my '10 was tighter than that.. .. much tighter.
    I'd take it back and show that to the service manager.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
    Aug 2009
    Canada/Ethiopia/Madagascar
    If you have ramps or a jack and stands I'd inspect the shifter linkage under your car. Take a look at the shifter pivot, and the shifter stay (a.k.a rear shifter bushing). Based on the degree of side to side movement there's a good chance the linkage isn't seated in the stay. Remove the boot/surround as well.
    Wouldn't want to lose the ability to shift gears on the way back to the dealership. You would likely have a 100% chance of fixing it yourself but I'd take it back regardless since you paid them to do the job right.
    ...Rob.
    [my photos]
    ClubWRX.net Vendor KronosPerformance's Avatar
    Nov 2005
    Bordentown, NJ
    Quote Originally Posted by mudferret View Post
    I was thinking the same thing, the rear shifter bushing may need to be replaced to reduce the side to side play that is known to occur.
    ClubWRX.net's #1 Vendor! - www.kronosperformance.com - Call/Text 732-742-8837 |
    AIM Screenname - KronosParts | GoogleTalk - sales@kronosperformance.com | Military Discount
    [/SIZE]
    USE COUPON CODE FIRST5%OFF to receive a discount of your first order
    Kronos has Special Pricings on Process West & Agency Power!
    CONTACT US DIRECTLY FOR SPECIALS AND PROMOTIONS
    Jul 2011
    Thanks for your help guys. I called the dealer and they said that definitely isn't the correct behavior. They couldn't get me in until tomorrow, so I'm taking it in then. They didn't think it would be a problem driving today and tomorrow, but I'm still a bit nervous.
    Lesson learned: take time to check anything installed at the dealer, and trust my judgment. Also, investing in some ramps might be a good bet, and getting more familiar with the car!
    - Eric
    Aug 2010
    Yonkers/NYC
    Quote Originally Posted by 5oclockfriday View Post
    good idea Just ask the dealer exactly what the issue was.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    Kimi Räikkönen
