Results 16 to 30 of 32
This is a discussion on Clutch Noise? Need help please =[ (2011 wrx) within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Mine does it on cold starts as well for just a couple of minutes, but I also don't think it's ...
    Registered User ElVerde's Avatar
    Aug 2010
    Newport Beach, CA
    Mine does it on cold starts as well for just a couple of minutes, but I also don't think it's much of a big deal. I freaked out the first time I heard it, though
    ~ADAM
    70 El Camino SS clone
    2011 WRX Sedan in Satin White Cobb Stage 1+AEM Cold Air Intake
    Click here for my Progress Thread
    Installing HellaSupertones? Click here.
    N.E.R.D. #4
    Devout Practicalist
  2. #17
    Registered User hisdigness's Avatar
    May 2010
    So Cal (Torrance)
    If it were throwout bearing chatter, would the sound not be persistent? I just don't get why it only goes away when warm...gotta be something else.
  3. #18
    Registered User SamXp's Avatar
    Nov 2010
    Winston-Salem, NC
    I had a 1998 Mustang that did this when I bought it, and then Ford released a Bulletin to switch to a new Throwout Bearing and replaced it under warranty and the sound went away. Not a huge issue, but do hope Subaru keeps an eye on it. Sound is energy, and if there is enough energy being produced to make noise, then it is likely that some internal damage is occuring in the bearing.
  4. #19
    Nov 2010
    Winston-Salem, NC
    Quote Originally Posted by hisdigness View Post
    Cold lubricants? Tight tolerance? A little heat could cause the bearing to expand and open up the raceway.
  5. #20
    May 2010
    So Cal (Torrance)
    I see, thanks for the clarification!
    I will report back in August after hearing what the dealer has to say. Thank God for warranties!
  6. #21
    Mar 2010
    hmm my mind is put more at ease now LOL. But still worried and will wait for that august report!
    ty all! <3?
  7. #22
    Registered User Erikjenkins11876's Avatar
    Feb 2011
    Frederick, MD
    My 90 Ford Festiva had TO bearing noise, so did my 98 Ford ZX2, my 2000 Eclipse GT, and Focus SVT. TO bearing noise in neutral to a mild extent is completely normal. Trust me, you'll KNOW if your TO bearing is BAD, it makes an unholy racket.
  8. #23
    U.S. Combat Veteran (3ID) Stu_Gotti's Avatar
    Jan 2011
    Southern Maryland
    I'm having a similar noise while at startup.. it sounds like a cricket on bath salts.. but no seriously it sounds like a weird chatter.. whistly almost.. figured it may be my throwout bearing chattering but didn't know if there was a way to help reduce the noise.. sounds horrible coming from the car.. reading all of the issues everyone is experiencing from Subaru it almost seems like its not worth my drive to the dealership..
    11' WRB Limited WRX Sedan
    Cobb AP Stage 2 93 + SF | Cobb SRI | Cobb DP | SPT STS | RA Flaps w/Blue | Pro-Clip | KB Black Aluminum Shift Knob
    KB Front & Rear Shifter Bushings | 18x9.5 +40 Gunmetal Rota D wrapped in BF Goodrich G-Force 265/35/18
    Yakima Roof Rack Complete System w/ Highroller Bike Rack & Yakima Fairing | 35% Tint | Full Sound Dead | Kicker BassStation 2ea. 12"
    "I may appear calm, but in my head I've killed you three times."
  9. #24
    May 2010
    So Cal (Torrance)
    Hey I actually ended up selling my 2011. I recently came back to the WRX and purchased a 2012. I get the same exact noise. I simply let the car warm up to operating temp now in the morning and it doesn't make that sound anymore. If I don't let it get completely warm it does whistle!
    Quote Originally Posted by Stu_Gotti View Post
  10. #25
    Jan 2011
    Southern Maryland
    Yeah I'm often guilty of not letting it come to full operating temp.. guess I need to adjust my routine lol.. thanks for the feedback!
  11. #26
    May 2010
    So Cal (Torrance)
    Sure. It sucks because it can take up to 5 mins to warm up and I feel like I am just sitting there raping my gas...lol
    I need to look at the manual to see if we are even supposed to let it warm up that way. My BMW 335i said to not just sit there, and in fact drive it slowly until warm.
    Also, weirdly I get a springing sound from the rear (diff) I think when going from reverse to first. But after reading I see that is pretty normal too.
  12. #27
    Jan 2011
    Southern Maryland
    Well I'm just above 25K miles at this point. I'm due for services by now, although I've done most of the stuff myself. Guess I'll see what they say.. have to make an appointment to just have them once it over.
  13. #28
    May 2010
    So Cal (Torrance)
    Ah good luck with the dealer. I tried once and even left it there over night, since it only happens on the first cold start of the day.
    "we were unable to replicate the noise."
    Annoying! I should have told them not to start it and gone there and started it with them, but that is way more work that simply letting the car warm up. HAHAHA
  14. #29
    Jan 2011
    Southern Maryland
    Here is two videos I took last night of the sound. Best way to describe what I'm hearing now.. is when you ran as fast as you could on Super Mario 3 and the meter was full lol. You can hear/see in both videos when I slightly touch the clutch pedal, not even depressed hardly, the noise stops completely. Only when I release does it start again. I assume what I hear may be my TO bearing chattering.. although I hope the quality of the video may help those interested.
    http://www.youtube.com/watch?v=VfB4C...re=context-gau
    http://www.youtube.com/watch?v=Y-Mu_...&feature=g-upl
  15. #30
    May 2010
    So Cal (Torrance)
    Yep here is the video I made over a year ago on my old car.
    Cold start clutch whistle - YouTube
