Newbie to Subies - Page 3
Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 71
This is a discussion on Newbie to Subies within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Or going FMIC... but yeah heat shields would do the trick. I've seen and heard of other ways to keep ...
  1. #31
    Registered User Scooby_K's Avatar
    Jul 2011
    FL
    Or going FMIC... but yeah heat shields would do the trick. I've seen and heard of other ways to keep the charge air temps down with cryogenic methodologies with a close-loop cooling system, but that is for some people who have money to burn, and besides...is it reasonable to be putting the foot in it everytime? I guess in Colorado the air temps at night and in the fall and winter months keeps things cool enough and charge air molecules all fat with oxygen
    Current ride: 2001 Kona Mama BMX... a classic!
    There are 3 types of people in this world...those who make things happen, those who watch things happen and those who wonder what the hell just happened
    Pipe Hitters Union member
    http://www.wheeldude.com/wdg/ul/inde...ery/5154_2.jpg
  3. #32
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    With a fmic you need to have a large turbo, otherwise your making it worse instead of better. As i said, I am trying to get some i/c spray but the seller is busy.
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
  4. #33
    Jul 2011
    FL
    Exactly how small is the factory turbo? Are the Subies the only car on earth that don't benefit from a FMIC? Hmmm...
    Have you thought about an ethanol kit?
  6. #34
    Jul 2009
    I am not sure how the turbo compares to other turbos, as the wrx was my first turbo'd car. I know the tmic is efficient with less piping though.
    I dont think that would be good for me and i like the stock sti ic spray kit.
    Josh
    Bugeye mafia #300
  7. #35
    Jul 2011
    FL
    I meant "methanol/water" injection. The methanol is an octane booster while the water keeps temps down and cools your charge air (which is what the IC is supposed to do; in this case, you get the benefit of a bigger IC with the assist of methanol/water)
    Benefit of methanol/water injection:
    - cooler charge air
    -steam cleaned combustion chamber and valves
    -drastic reduction in engine ping/detonation
    Your windshield wash is methanol/water
    check this link for more info Do It Yourself Water Alcohol Methanol Injection
  8. #36
    Jul 2009
    Interesting.I don't know how I feel about the injection.
    Josh
    Bugeye mafia #300
  9. #37
    Jul 2011
    FL
    beats using the stock external water mist system, and you get the added benefits as I mentioned. Just worth looking into IMO
  10. #38
    Jul 2009
    But the install is much easier
    Josh
    Bugeye mafia #300
  11. #39
    Jul 2011
    FL
    I suppose
  12. #40
    Jul 2011
    CA
    Is a tune required for any turbo upgrade?
  13. #41
    Jul 2011
    FL
    Yes, it is recommended. Why? At idle and at normal cruising, all seems normal until you put your foot into it. A turbo upgrade is usually for one that pushes more flow, and with increased air flow (more air being pushed into the intake) you will need a proporational amount of fuel to keep the mixture of fuel and air in proper ratio throughout the powerband. Too much air and not enough fuel will cause "lean out" and too much fuel and not enough air will be a "running rich" condition. Depending on what you are trying to achieve, you must always take in consideration the flow of your injectors, the fuel pressure regulator, fuel pump, the turbo rating and the things that will enhance efficiency, and a computer tune to put all these things in consideration is a must do unless you like making more probs or creating a catastrophic fail condition. Find a reputable tuner, talk to him or her and state your needs/desires and go from there. In the end, you will save money and a big bag of grief. Just trying to put things in a simple perspective.
  14. #42
    Jul 2009
    Looks like you know what you talking about now..
    Josh
    Bugeye mafia #300
  15. #43
    Jul 2011
    FL
    Quote Originally Posted by yamaha_rider619 View Post
    I've been around cars since the mid-90s and have learned from the school of hard knocks I'm new to Subies, but I am reading up on common probs and seeing that Subies do have their own issues, but things like increasing turbo size needs to have all the things I mentioned taken in consideration and actually done, just as you have said and demonstrated
  16. #44
    Jul 2011
    FL
    Ahhhhhh! Man... it seems that I should be looking at newer models based on all the quotes I have been getting... It seems banks don't want to finance anything greater than 5 years old... Hmmm...what to do...
  17. #45
    Jul 2009
    A plus with getting a newer wrx is from 06+ they have 2.5l instead of 2.0l. IMO 06/07 or 2011 is the only newer wrx's that I would buy.
    Josh
    Bugeye mafia #300
