Results 1 to 9 of 9
This is a discussion on Hey guys, I'm new here. I drive a 2003 WRX sedan. Need a bit of help. within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Hi I'm Jess!! I'm from Sydney, Australia & I own a Graphite Black 2003 Subaru WRX sedan (2.0L, 5-Speed) - ...
    Registered User JESSIKAT's Avatar
    May 2011
    Sydney, Australia
    Exclamation Hey guys, I'm new here. I drive a 2003 WRX sedan. Need a bit of help.
    Hi I'm Jess!! I'm from Sydney, Australia & I own a Graphite Black 2003 Subaru WRX sedan (2.0L, 5-Speed) - Just thought I'd introduce myself, Lol..
    So I've come across a little problem as of late..
    I go to turn my car on, It turns over slightly but the engine does not ignite. Battery is brand new & new spark plugs. There is a new fuel filter & pump too.. Anyone else had a problem like this? I thought that it could be the petrol but I only use premium? It's happened 4 - 5 times now.
    It was only serviced last month (It has 90,000km on the clock)
    The mind boggles!!
    Nov 2009
    Got any aftermarket electronics installed.
    And welcome to the club. Where are the pics?
    May 2011
    Sydney, Australia
    Thanks!!
    Yeah I've got the usual sound system getup (Amp, Sub etc) Was all professionally installed too.
    But other than that no.
    Took off my turbo-timer because it kept interfering with my alarm/immobilizer. Would that have anything to do with my 'problem' though?
    I'm just learning how to use this site so I'll upload some photo's asap!!!
    Apr 2007
    8000' up in Colorado
    So it doesn't happen all the time just sometimes?
    Scott
    Registered User 2002_wagon's Avatar
    Feb 2009
    Orlando, Fl
    Distrubuter cap injectors not giving u fuel or getting to much idk im just throwing out suggestions. Hope u get it solved good luck and welcome
    278whp 286tq blouch 16g @ 17.5psi
    "My 02 wagon build" http://www.clubwrx.net/forums/everyd...gon-build.html
    Operation Iraqi Freedom x3
    WRX wagon MAFIA #68
    Nov 2009
    Start off with the basics. Go over every cable On the battery and make sure it is clean and tight. Afterthat look at all the grounds. I have seen a lo of bad wiring jobs when audio Eqp is installed. If all that looks good then maybe he starter is bad. You could try hitting it with a broom stick while someone cranks the engine.
    Registered User DKDunn04's Avatar
    Mar 2011
    Colorado
    Do you have a chip in your key? If you have another ignition key, try that. I had this exact problem with my wifes cadillac, and it was the key.
    May 2011
    Sydney, Australia
    Thanks for all of the reply's everyone!
    It only happens sometimes & Not when the engine is cold either. I do have a chip in my key, I'll try my spare to see if that helps. If not off to the mechanic she goes. I've just checked as much wiring as I could (Engine bay & AMP) & everything seems fine. I think it could be in internal problem.
    I will keep you posted!
    Registered User crisco's Avatar
    Jun 2011
    Skyline Drive
    good luck and nice WRX
    --- 1999 Impreza WRX STI JDM Version 5 Sedan ----
