Any more info on where it sounds like it is coming from, front, rear, left, right?
This is a discussion on rattling deceleration noise within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Im new to this just bought a 02 wrx stock with 70k on it and when in gear i let ...
Im new to this just bought a 02 wrx stock with 70k on it and when in gear i let off the gas around 2500 3000 rpms and there is a rattling noise iv been told wrx have heat sheilds and a lot of exshaust guards is it possible its that or my transmission? because the car shifts and drives great.
Contributing unsolicited, worthless opinions since 9/10...
The project I spend all my money on.... <---- Click it
Without having much info to go on here, you could also check your exhaust hangers. A car of that age from NY probably has a loose heat shield or two however as mentioned above. You can check your exhaust manifold and up pipe shields by removing the engine undertray and crawling under there, down pipe heat shield by popping the hood. Also a heat shield just before the axle back, can't recall if there are any others in between.
...Rob.
the sound comes from the front
thanks il have to check those out
I noticed a rattling on mine the other day too, when I was engine braking in 3rd from 5-3k RPM. Freaked me out. I read somewhere that it's normal?
2011 WRX Limited w/ Nav, Tach Motor Works & JR Tuned - Stage 2+ ~ 306 awhp 328 ft/lbs @ 19psi
AEM Intake, Process West TMIC, GFB Respons BOV, Invidia Q300 Turboback, Grimmspeed EBCS
AEM Wideband & Boost Gauges, SMY Cluster, SPT Short Throw Shifter/Bushing, Anarchy Motive Shift Knob, 30% Tint
ya i heard that to i guess a lot of them have that rattle so im not to worried about it i just wanted to make sure
Mine rattled and then i found out my former shop set my ring and pinion wrong and it shredded all the teeth in my tranny![]()
278whp 286tq blouch 16g @ 17.5psi
"My 02 wagon build" http://www.clubwrx.net/forums/everyd...gon-build.html
Operation Iraqi Freedom x3
WRX wagon MAFIA #68
how do i check if those are set wrong?
and did they fix your tranny for free
Your up-pipe heatsheild welds probably came untacked. Everyone that is still on the stock 02-03 up-pipes have had this problem. Sounds like dookie. Get an 06+ up pipe, I just sold mine for 25$ and you wont have to worry about the cat going bad and ruining your turbo.
Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
Stable: 07 GMC 2500HD, 06 LGT, What's left of an 04 STI, 03 WRX, 98 RS, 86 Brat
Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
ya when i first heard it i was scared that something was wrong with my tranny but i did start looking around and a good amount of people have had this problem and thanks for the info il have to get one
