uppipe vs. NH emmisions test
Results 1 to 15 of 16
This is a discussion on uppipe vs. NH emmisions test within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Does anyone know if you complete a uppipe mod on a 02 wrx, when you plug the egt hole and ...
    Registered User Lastchance43's Avatar
    Feb 2011
    NH
    Does anyone know if you complete a uppipe mod on a 02 wrx, when you plug the egt hole and bypass the wire so the check engine lite stays out, will it still pass emmesions test and even though the light is out does a code still come up on the scanner?????In the great state of NH, if you have a check engine light or obd 2 scan test shows a code, that means no inspection sticker...thanks for the help
    Feb 2010
    SL,UT
    If you bypass it and delete the DTC code/s then it is all up to the sniffer and visual test to determine if you are leagle...
    Hawk-Eye Alliance #801
    Feb 2011
    NH
    im not concerned about the visual test because im going to use a stock pipe but punch it out. as far as the obd test im def concerned that the computer will pick it up. i will have to look alout deeper on this.....thanks
    If by "bypass the wire" you're referring to the resistor fix, there should be no stored CEL.
    Resident Tuner @ WTF Tuning
    Feb 2011
    NH
    thats the answer i was looking for thanks man. can't wait to start taking it apart.
    Feb 2010
    SL,UT
    Delete the DTC codes/s via accessport or romraider, reset the ecu and goodbye CEL...
    Quote Originally Posted by Lastchance43
    My advice: buy another uppipe, gut it at your own leisure, install gutted uppipe, sell the one on your car (or keep it to reinstall if/when you part the car back to stock for sale).
    Uppipe gutting can be a PITA, and if you run into an issue during the process (I've snapped drill bits in the cat and had to go buy new ones), you can be without a driveable car. Secondly, you want to make sure there are no pieces of cat material left in the uppipe that can be sucked into the turbo (not rushing to get the uppipe reinstalled will help). I've done a few, and gotten best results with a long drill bit, long flathead screwdriver, rubber mallet, and a wire brush drill attachment for "cleanup".
    More importantly: you want to make sure it's done in a well-ventilated area (I always do it outside) and use respiratory protection.
    Quote Originally Posted by 06scoobyrex
    It's still a good idea to do the resistor fix, since if the circuit is left open, the ECU will try to compensate by adding fuel.
    Feb 2011
    NH
    ya i read that in your post. i will buy a aftermarket one or a sti one so i can exactly do just that and put mine back on when i sell car.
    There would be no need to gut the uppipe, then, since either of those will be catless. In theory, aftermarket should be superior to either OE option (OE 2.5L or gutted OE 2.0L) based on design, but you would likely not be able to notice a difference (especially at lower mod levels).
    Feb 2010
    SL,UT
    True... the resistor fix is a very good option, I just wasn't sure if he was in a big hurry cause it is mid month... I have to ger restickered as soon as my car gets fixed... bad timing I guess...lol
    Quote Originally Posted by 06scoobyrex View Post
    I would think that someone being in a rush would be more prone to drive to any electronics store like RadioShack to buy a $1 or less resistor, rather than spending $100+ then waiting for the AP/Tactrix to get shipped
    Feb 2010
    SL,UT
    Assuming he doesn't allready have 1 or acess to one... I was thinking that you had to special order the resistor too as well... sorry for the flawed judgement...
    I'm just busting chops, man
    Registered User gluis's Avatar
    Apr 2010
    Caracas, Venezuela
    Hello all,
    Is there a how to gut the uppipe cat thread? Can anyone point me to it?
    Best regards,
    GS
    Feb 2010
    SL,UT
    Yeah... I know man...lol
