Fuel cutoff?
Results 1 to 15 of 23
This is a discussion on Fuel cutoff? within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; When i am gettin on it my gas shuts down at 5000rpm in 4th gear and about 6000rpm in 5th. ...
    Jan 2011
    Fuel cutoff?
    When i am gettin on it my gas shuts down at 5000rpm in 4th gear and about 6000rpm in 5th. when i let off the gas and press the gas again its fine. Anyone know what this could be.
    Registered User metaldahlberg's Avatar
    Sep 2010
    NH
    Any mods to the car?
    Contributing unsolicited, worthless opinions since 9/10...
    The project I spend all my money on.... <---- Click it
    Jan 2011
    Quote Originally Posted by metaldahlberg View Post
    Yea. Blouch 16g, runnin 8 or 10 psi. Haven't had the chance to boost it up since I got it. Hks turbo back exhaust, big top mount, walbro fuel pump, hks down pipe. Believe that's it for now.
    Registered User MakeItRoar's Avatar
    Aug 2010
    Chicago, Illinois
    5000 RPM's in 4th, 6000 RPM's in 5th? For the love of god, how fast are you going? It may be the governor, if you're hitting that high in a five speed. So I'll assume you have a 6-Speed, and still ask the same question as before, why are you going so ****ing fast? Year? Model? Mods? Those would help a diagnosis.
    2006 WRX Limited -Pro-tuned VF-39, STI TMIC, STI factory I/C Sprayer, Throttle body Coolant Bypass, STI Exhaust, SPT Short Ram Intake, SPT Upper Front and Rear Strut Bar, Red Samco Radiator Hoses, STI Trunk, SPT Short Shifter, Aftermarket Rotors, Lamco Turbo Gauge, Catless Downpipe, Hella Supertones, RallyArmor Limited Edition Pink UR Flaps, 35% Tint, Grounding Mod, Walbro 255 Fuel Pump, SPT Heat Shield STI Piston Shift Knob!
    Hawk-Eye Alliance #430
    Jan 2011
    Its definitely a five speed, I redline at 7000.. So around 140Mph. Even if it were a six speed I would still push it to the top..Lol But I have a blouch 16g, big top mount, hks turbo back, walbro fuel pump, up and downpipe. It's an 02 wrx
    Aug 2010
    Chicago, Illinois
    Quote Originally Posted by 02Kevin View Post
    Uhhh, Injectors? You may just be maxing those out, because they can't keep up for the long stretch of high demand. In lower gears, in WOT, you redline for a few seconds, and shift. At 140 mph, you're at the redline all day, and you're finally noticing that injector limit. If you need this kind of power everyday, I'd suggest installing a few firehoses between your fuel pump and your engine.
    Jan 2011
    No they are the stock injectors. So that cut off is more than likely the injectors hittin their limit..?
    Aug 2010
    Chicago, Illinois
    That'd be my thoughts. You can upgrade the fuel pump all day, but if you leave stock injectors, you're not gaining the fuel delivery that you're looking for. Did you upgrade your fuel lines/rail? Upgrade that and move to bigger injectors to keep up with the 16G. My guess, you've been running heavy lean with that 16G. Are you tuned? You need a tune STAT if you don't want to be picking up parts of your car along a 50 yard trail. How long have you been running the 16G? Might wanna do a compression/leak down test, and hope you didn't **** a piston or anything. 8-10 PSI is not much, so you may have gotten lucky, but did you do the turbo swap yourself? Did you do research on supporting mods? Also, stock BPV? If you want to tune that 16G, you'll probably want to go with a forged BPV, depending on your PSI numbers.
    Jan 2011
    I am tuning it and bumpin up the psi with tax return $$. So that will be happenin within a couple weeks. And I bought the car not to long ago with the mods it has now. No upgraded fuel rails.
    So..
    1. Upgrade injectors, fuel lines/rail and bpv
    2. Get a tune
    Should be sittin good?
    Aug 2010
    Chicago, Illinois
    So..
    2. Get a tune
    As I think about it, I would get a leakdown/compression test to be safe. Also, make sure you ask your tuner for his recommendation on injector size, and the necessity of a new rail, because the stock fuel rail can handle a little higher than stock injector flow, but not too much. Depending on the power you're putting down, you may want to upgrade your intake, seeing as you're getting a tune anyway. Some say the stock intake is good for some pretty high numbers, but it's more an owner and tuner choice. IMHO, you should also get a boost gauge, it will help TREMENDOUSLY with an aftermarket turbo, to monitor any problems before they kill you. Do you have another car to drive? If not, I'd be careful with this one, and would recommend staying FAR from 140 mph/redline. Every second is wear and tear that you don't need when you aren't tuned. Your tuner will discuss anything else he sees with your car, because I'm obviously not there. Make sure you treat him well, and take his recommendations seriously. He can save you with a little tactrix cable, and a computer, and his brain. Also, make sure your turbo is installed correctly. Many larger require a larger oil feed line, which you may not have. This will really shorten the life of the turbo, and rob you of some power. Where are you located? Make sure you get a reputable tuner, and not some guy in his garage with a tactrix cable and a laptop. Dyno tuning is the way to go, and it's worth the higher cost. No matter what, the tune is not something to put off, you damage your baby everyday you drive it, and you need to be running the correct map as soon as possible. Good luck. The rest is between you, and your future best friend, your tuner.
    Jan 2011
    I have a Perrin intake and a boost gauge forgot to mention.. But I have a reliable and recommended tuner about 30min from my place.. Thanks for all the help. Much appreciated, more questions will be coming soon.
    Aug 2010
    Chicago, Illinois
    Haha, well i guess you're set except for tuner consulting. No problem, good luck with the tuner, and we'll be here for your questions to come as well.
    Apr 2007
    8000' up in Colorado
    Quote Originally Posted by MakeItRoar View Post
    Seriously.....
    And how old are you and where are you doing these speeds? Sorry, but you'll get no help from me until you slow down and learn how to drive. You just got the car, don't really know how to drive it, but you're doing 140?
    Good luck living very long.....
    Scott
            MainFrame's Avatar
    Austin, TX
    Seriously.....
    Not to mention the car has a turbo swap and NO TUNE. I'm surprised it still runs.. I guess it's only a matter of time.
    Aug 2010
    Chicago, Illinois
    Sorry guys, didn't mean to assist the dangerous speed demon... And I have no idea how a 16G works on a tuneless '02. I figured he's basically destroyed his inner workings, but I still don't understand how most of it is possible.
