Results 16 to 30 of 36
This is a discussion on 2011 WRX needs Synthetic oil within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; I'll check it out, got to go pull the file. I know I bought the extended warranty and another a ...
    Registered User Grains's Avatar
    Oct 2010
    Santa Cruz, CA
    I'll check it out, got to go pull the file. I know I bought the extended warranty and another a maintenance plan, it's just to much to remember off the top of my head.
  2. #17
    Apr 2007
    8000' up in Colorado
    The oil change interval on the new 911 is now listed at 20,000 miles. It used to be 15,000. That gives you a good idea how long synthetic can really last.
    Scott
  3. #18
    Oct 2010
    Santa Cruz, CA
    Ok got the paper work out, this plan I bought covers oil changes, replacement oil, and all fluids. Spark plugs, engine coolant, fuel filter, air cleaner element, differential lubricants, brake fluid, and inspections of all suspension, steering, brakes, brake lines, clutch, front and rear axle boots, and shaft joints. It also gives me roadside assistance 7 days a week 24 hours a day. Not sure if it's worth it but I have it.
  4. #19
    Apr 2007
    How much did that cost you?
    Scott
  5. #20
    Dec 2010
    If you dont mind me asking, how much did this cost you? at 70.00 an oil change, i am curious what the cost/benefit would be. Im seriously considering changing the oil myself, its the location where i can do this that i have to figure out! :-)
  6. #21
    Jan 2011
    Quote Originally Posted by dbya rx View Post
    its funny. subaru finally bit the bullet and changed the requirements. my booklet for MY2010 says nothing about synthetic being required. that didnt stop me from using synthetic b/c i had a feeling they were going to change that sometime down the road, but maybe subaru should send something out to all owners.
    wat did that synth oil change at the dealer set you back? over $100?
    I'm getting my changed today at Mann-Engineering in Santa Clara in about an hour. They quoted me $70.
  7. #22
    Registered User dbya rx's Avatar
    Jul 2010
    San Marcos, California, United States
    Quote Originally Posted by bposeley View Post
    DIY!!! you will save $$$ in the end, and you get a pretty great feeling after you do it, like you accomplished something. you may have to put some $$$ upfront for the tools if you dont have any, and you will definetly need drive-up ramps to lift up the frnt on the car (that is if you dont have jacks), but in the end, its cheaper and its fun.
    next time i change my oil, im going to take some photos and write up a DIY guide for all of the 08+ owners. when i changed my oil the first time, i went into it kinda blind b/c i couldnt find any DIY guides. it can be done with MINIMAL mechanical knowledge. i guess since i have done it 3 times now i think its easy, and some may say a DIY guide is not necessary for something as simple as changing the oil, but man, the first time on an almost $30k car is pretty nerve-racking.
    Stink-eye Mob #814004
    2010 WRX Limited Hatch - spt short throw...for now
  8. #23
    Registered User Chader's Avatar
    Jan 2010
    Billings, MT
    A guide would be nice. I am ready to do mine the first time and couldn't find one. I suspect the plastic guard needs to come off. I just need to find the correct tools and all the fasteners.
  9. #24
    Apr 2007
    Yes, take off the plastic skid plate. Other than that, it's pretty simple. Reaching the oil filter is probably the toughest part.
    Scott
  10. #25
    Jul 2010
    Quote Originally Posted by Chader View Post
    i dont have to change my oil again for a few thousand miles, so cant do the guide until then...
    all you need for the undercover is a socket wrench for the 4 bolts that hold it in (part #3). there are 2 large fasteners (clips) along the rear of the undercover (part #4) that are pretty sturdy, you dont have to be super carefull with these, but make sure you notice their orientation and which side is up/down so you can put them back. the 2 small clips that go into the fender apron (part #2, one left and right) are total beeotches to get out. they are small, and tough to see, and i broke one the first time i took it off. use a small flathead screwdriver, and slowly and gently pop out the center piece of the clip. this should loosen it up enough that you should be able to pull the entire clip out with your hand or the flathead. MAKE SURE you pop the center part of the clip out before trying to remove it.
    that is the hardest part, other than getting the filter off. the first oil change is usually the hardest b/c the filter is on there so tight from the factory. go to an auto parts store with the replacement filter and find a wrench, im talking a REAL WRENCH, no one of those lame filter tools they sell for $5. I broke one of the cheapos, and had to force a screwdriver thru the filter to get it off the first time.
    good luck, hope that helps.
  11. #26
    Jan 2010
    Billings, MT
    Thanks a bunch. I might have struggled with the other fasteners.
    Those fasteners sound similar to the ones I had to use when I put on my mud flaps.
    I have several filter wrenches. I bought the end style and already had three other types. So that should be possible with at least one of them.
  12. #27
    Registered User Eric05mx's Avatar
    Oct 2010
    PA
    That is insane for a turbo engine. I was talking to a guy at work today that has a 2010 BMW X6 and said the oil change interval is 15,000 miles using German Castrol. As long as they stand behind I guess.
    Quote Originally Posted by Grains View Post
    Well, it looks to be worth it if they are going to change all that stuff when the manual suggest.
    2012 WRX ice silver metallic
    Protuned by Agile Auto 315whp/342wtq @ 20.5psi
  13. #28
    Apr 2007
    Quote Originally Posted by Eric05mx View Post
    I wouldn't go that long myself for sure, but that maintains your warranty. I went 10k between changes on my old 911 but on my new one, it's 7-8k and I don't track it. It does make a huge difference that the overall oil capacity is 10 quarts which means there's a ton more additives to burn up than in a standard 5 quart car.
    Scott
  14. #29
    The Fruit mangostick's Avatar
    Oct 2009
    the ghettooooo
    My dealer must be under-charging me for full synthetic oil changes.. They're usually about $45 .. $78 with a tire rotation included. I keep to the 3750mi interval more so because the car is still within warranty but even after that expires I'll likely stick fairly close to it. I'll likely move it to 4k mi just because its a nice even number.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
  15. #30
    Aug 2009
    Canada/Ethiopia/Madagascar
    I have a hard time moving away from my 5k km (3125 mile) oil change interval; I could likely stretch it another 1, 2, 3 k km safely, but I'm willing to "waste" my money. A 15 or 20k MILE interval would keep me up at night.
    More and more car makers are saying, my bad, we were just looking to make money, you actually only have to change your oil when there's a solar eclipse.
    FWIW, not running synthetic oil in a new, turbo charged car, is criminal IMO.
    ...Rob.
    [my photos]
