Results 1 to 12 of 12
This is a discussion on 2011 WRX fuel door wont open within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; I have had my wrx for about 2 months now, the first few fill-ups were fine, but for the last ...
    Dec 2010
    I have had my wrx for about 2 months now, the first few fill-ups were fine, but for the last few weeks, the fuel door wont open. Its not frozen, it just doesn't open when you pull the level - i have to jam something in the latch, or have someone hold it while i go and pull it open with my fingers - i only have 2200k on it.
    Anyone else have this issue? I'll have the dealer look at it at the 1st oil change. Ive tried to pull the metal thing that acts as a spring but that that doesn't help...........
    Apr 2007
    8000' up in Colorado
    There's a couple of threads on here about this. Seems to be a common problem...
    Scott
    Registered User ElVerde's Avatar
    Aug 2010
    Newport Beach, CA
    Yup...same problem here...
    I'm going to look into a solution...I'll let you know if I have any luck.
    ~ADAM
    70 El Camino SS clone
    2011 WRX Sedan in Satin White Cobb Stage 1+AEM Cold Air Intake
    Click here for my Progress Thread
    Installing HellaSupertones? Click here.
    N.E.R.D. #4
    Devout Practicalist
    Dec 2010
    I'll do the same here - if it wasnt so dam cold, i'd try and get into the panel and see if its the cable or something - but with no garage, I'll deal with it for now........
    Aug 2010
    Newport Beach, CA
    Quote Originally Posted by suby04 View Post
    the release seems to work fine...it's just the fact that the door doesn't "pop" open. I think it's spring loaded in some way. If I can't get to it...back to the dealership we go!
    ~ADAM
    N.E.R.D. #4
    Devout Practicalist
    Oct 2010
    i had this happen to me on x-mass day! so sh**y when it is cold and you are late! i was abble to prop the relese hand up with my knife. the door would move but would not pop. i used a key and my shirt to pull it open ever so nicely. the door had two small 1/4 inch dots of ice on the inside top edge of it they where what was holding it shut. it was about 5 out when i was trying to get it open. i could see the ice poping off and never have konwing it was their(it maybe luck that i saw them?). Have not had any other trubble with it. dont know if it is the same problem as everyone else but i thought i woud add my 2 cents.
    Nov 2009
    This is an easy fix. Slightly bend the little latch that holds the door. Did this on my car and haven't had an issue for about 3 years.
    Registered User AmateurX's Avatar
    Jul 2009
    Troy, Michigan
    Mine doesn't pop open either, as I had suspected it would. Instead of trying to pry it open from the left side of the door, I just push the right side of the door in, and it pops right open!
    2011 WRX Limited, DGM; full tint, SPT CBE/STS w/ bushings, RA flaps, Enkei PF01s, Pink SuperTones, and ClubWRX.net stickers!
    My Photostream
    about.me
    Dec 2010
    UPDATE: Well the dealer fixed the door, they said the spring clip was "misaligned". I checked the flimsy clip and it looked like i was in the same place it was before. Anyway, the door does open, although its a very weak spring open. We'll see if its a case of a few uses and the clip will become "misaligned" again, or if its actually fixed. :-)
    Dec 2010
    Boise, ID
    If this ever happened to mine and the dealer couldn't fix it, I would put glue rare earth magnets to the door and frame with the polarities aligned so they reject. It's kinda ghetto but what the heck...
    Apr 2007
    I've definitely noticed the fuel door is very cheap and flimsy versus the fuel door on my '04. I'm sure that contributes to the problem.
    Scott
