There really is not a difference in the actual methods of installing an alarm between a manual and an automatic, some alarms have an autostart feature which you obviously won't want in you manual as it could be dangerous due to possibility of it being in gear.
I would say that if you are good at following instruction manuals and have the wiring diagrams that are needed for your model year that you will be fine. I have always soldered my connections and used heat shrink over the soldered connections, if you don't have a soldering iron I would recommend the connectors that have glue in them so when heat is applied to the connector after it is crimped the glue goes off and the connection is super strong, that would be my recommendation for you. I can not tell you how many crappy installations I have seen and removed over the years.
LinkBack URL
About LinkBacks
