Results 1 to 15 of 20
This is a discussion on Many questions within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; I just got a 2008 WRX Hatch. I am wanting to do the beginners mods first. As of right now ...
    Registered User steve02008's Avatar
    Nov 2010
    Livermore, CA
    Many questions
    I just got a 2008 WRX Hatch. I am wanting to do the beginners mods first. As of right now it has a cat back exhaust, AEM intake, lowered and 17" rims. I am new to this gas thing, been tuning and makeing diesels go fast. Any help would be appreciated.
    Welcome
    Nov 2010
    Livermore, CA
    Many questions
    Thanks any addvise for me would be greatly appreciated
    What are you trying to modify? Suspension? Brakes? Driveline? Engine? Stereo? Interior? Exterior?
    Nov 2010
    Livermore, CA
    Many questions
    Sorry about that. I am looking to do so quick DIY engine mods, Suspension mods that would compliment the car already being lowered, what gauge placements look the best in the Hatch, I already have boost, egt, and fuel pressure.
    Quote Originally Posted by steve02008
    http://www.clubwrx.net/forums/engine...hp?t=134325261
    Your next step is a downpipe and a tune.
    http://www.eqtuning.com/index.php
    EQTuning is a pretty well-respected shop not too far from you. Contact them when you're ready to install the downpipe and see what Ed has to say.
    Quality tires/alignment
    Sways/endlinks
    Clock pod
    A-Pillar
    Nov 2010
    Livermore, CA
    Many questions
    you can still do an a-pillar pod with side air bags? car has been aligned and I was told that the tires were good. I am used to 38" tires. lol.
    What tires are on the car? The tires are the most important aspect of the way the car handles.
    What alignment specs you have? OE spec sucks in terms of performance.
    Nov 2010
    Livermore, CA
    Many questions
    The tires that are on it are Dunlop DIREZZA Sport Z1 225-45R-17. It was aligned to stock specs. The tire company is who told me the tires were good. Like I said I don't know one way or the other.
    So is it or is it not possible to do A-pillar gauges with SAS.
    Should I be installing a boost controler on it? If so what would be recommened for stock tuneing for now?
    Thanks
    If you have Z1 Star Specs, you've got great tires! I still recommend going with a custom alignment. There is a sticky in the suspension subforum which will give you a decent idea.
    My alignment is as follows:
    -1.5° Camber F
    -1.0° Camber R
    5.8° Caster
    Have you contacted EQTuning yet?
    zax
    zax is offline
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    what are you lowered on?
    Facebook me here
    Jul 2010
    Cincinnati
    -1.5° Camber F
    -1.0° Camber R
    5.8° Caster
    Sorry for the thread-jacking but how is your tire wear with those alignment specs? And how did you decide those were optimal numbers? I'm looking into re-aligning my car but I don't want to sacrifice tire wear. Car handles well but can always be better.
    Quote Originally Posted by jd92677
    No noticeable extra tire wear. I usually rotate my tires every time I'm on the lift, which is usually around every 5-6K miles.
    -1.5° is about the maximum you can pull out of the front with the stock hardware (sometimes you can only get -1.2-1.3°); I have camber plates on my car, but I didn't want to go too much more aggressive than that. I like a little less camber in the rear, so I asked for a half degree difference (required rear camber bolts, which were ~$40 from my dealership).
    Oct 2005
    Late Devonian
    Quote Originally Posted by jd92677 View Post
    I have run those specs for an extended period (don't get that much caster though). Tires wore evenly.
    Alignment basics
    Jul 2007
    I hate the South, GA
    do you have a tune for that intake?
