Results 1 to 6 of 6
This is a discussion on Help with bugeye fuel tank size please within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Ok so i bought my bugeye about 3 months ago and am totally inlove with my car. I cant really ...
    Registered User Bugeye Scoob CT's Avatar
    Sep 2010
    Cape Town, South Africa
    Ok so i bought my bugeye about 3 months ago and am totally inlove with my car. I cant really complain about fuel economy as my driving style various with the mood but i do get anything from 25,5 mpg to 30 mpg depending on how i drive.
    Now my question is this. What size tank should my bugeye have as all over the internet and all publications including the owners manual my car is supposed to have a 13,2 g tank but when i fill up from empty the most i get into the tank is no more than 9,68g.
    I have checked the tank for dents and i have also checked the breather for blockage but all seems fine. Any help or suggestions would be much appreciated
    zax
    zax is offline
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by Bugeye Scoob CT View Post
    2002-2005 USDM WRX had 15.9 gallon fuel tank (not sure if other markets had different size tanks). Sounds to me that you have a poor-reading fuel level sensor. Try running some Seafoam through the fuel tank.
    Facebook me here
    Gallons are not a good idea because there is more than one volume that equals one gallon. I suspect you are both saying the same thing about the max volume of the fuel tank.
    You are both saying the tank has a max volume of just over 60 liters. This equals both 15.9 gallons and 13,2 gallons, depending on who is measuring -- but in either case it's a little over 60 L.
    zax
    zax is offline
    Nov 2008
    Yes yes, you are absolutely right. 13.2 imperial gallons = 15.9 US gallons = 60 liters (I made the edit after I saw the OPs location -- after my post). Regardless, we are dodging the point of the original post, the OP is reading an empty tank after only 9.7 imperial gallons (no good!)
    Facebook me here
    My fuel indicator is pessimistic on the low end sometimes too though, especially if the car has just sat around for a few weeks. It's also optimistic on the high end, and falls non-linearly around midpoint.
    The real way for the OP to make sure there's no problem is to run the car dry, but I would not do that. I usually fill as late as possible, usually a bit past the point where I am beginning to worry, and I usually end up using less than 13 gallons as the US measures them. If the OP doesn't wait until absolute panic time to refill, I can see using less than 9,68 gals Imperial measure.
    zax
    zax is offline
    Nov 2008
    or perhaps the OP may wish to carry a gas can, drive some country backroads when the fuel light is on (until empty), and determine just how much fuel is left in the tank.
    Facebook me here
