what grade oil goes into the transmission
Results 1 to 8 of 8
This is a discussion on what grade oil goes into the transmission within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; yo wuts up guys what grade oil goes into the transmission for a 2002 subaru wrx wagon 5 spd im ...
    Aug 2010
    New York
    yo wuts up guys what grade oil goes into the transmission for a 2002 subaru wrx wagon 5 spd im using 75w-90 idk if thts ok also what kind of oil goes into the motor meaning i use 5w-30 just want to know if thats ok both motor and transmission has 55xxx miles on it
    The owner's manual states the correct grade and viscosity for both motor oil and gear oil. Either will be at least slightly affected by your location and the ambient temperatures typical for that location. Check the manual. My car sees very different climate conditions and probably different use patterns than yours, and for mine the manual states GL-5 (MT-1 is implied IMO) 75W-90 will work.
    Registered User poly_poly-man's Avatar
    Feb 2010
    Rochester Institvte of Technorcery
    The owner's manual has a nice little chart for both those as to temperature vs. usable viscosity.
    Gear oil pretty much is 75w-90. However, if you're up to it, I'd suggest the gear oil ****tail - http://forums.nasioc.com/forums/showthread.php?t=920674 . Grimmspeed (at least) sells all 4 quarts in a kit, so there's no searching. Mix together, only add what you need after draining overnight.
    EDIT: what, I can't say ****tail here? man, good thing there's not a bartending thread in OT
    My big thread: The Used WRX Buying Checklist - Please Contribute!
    My current car: 2002 WRB WRX Wagon.
    Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
    I would not use that mixture in my gearbox and cannot recommend it in good conscience.
    There is an alcohol thread somewhere but it's mostly beer and wine stuff.
    Feb 2010
    any particular reason?
    There do not seem to be any data supporting its use, whereas what data are available seem to indicate stability problems, the originator of the mixture has generally not addressed criticism constructively, and the use of a mixture in and of itself seems to contradict the requirements of the gearbox manufacturer. Given that I think a better question mihjt be if there is a particular reason to use it.
    Dec 2003
    Dallas, TX / Sterling, VA
    Quote Originally Posted by poly_poly-man View Post
    It degrades prematurely and corrodes your synchros.
    Nov 2009
    OP stick with Subaru Extra-S.
