02 WRX wagon
View Poll Results: Should I get A STI exhaust?
Voters
4. You may not vote on this poll
  • Yes
    2 50.00%
  • No
    2 50.00%
Results 1 to 14 of 14
This is a discussion on 02 WRX wagon within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Hey, Just got my first Subaru to day a WRX wagon. Im soo excited but i have alot of preventive ...
    Registered User Salica's Avatar
    Sep 2010
    Orange county
    02 WRX wagon
    Hey,
    Just got my first Subaru to day a WRX wagon. Im soo excited but i have alot of preventive maintenance to do.. up-pipe, timing belt sigh is the timing belt neccessary? car has 110k
    -Salica
    Quote Originally Posted by Salica View Post
    Yes. The service interval is 105K, so many (most?) cars only get it changed once in their lives -- but it's necessary.
    Registered User Fritz_the_Chick's Avatar
    Aug 2010
    Detroit
    Doesn't it suck when you buy a car and then have to put money into it because you're not a rich so-and-so that can afford a brand new car that still smells perfect so you practically pay out like five car payments over the first three months of ownership for your gently used car that you thought would actually save you money?
    Yeah. It does suck.
    When you get the up-pipe, splurge and get the down pipe and catless exhaust and tune (note: catless exhaust recommended for off-road use only ) Do this, and you'll give your gently used vehicle a whole new outlook on life.
    Fast and Wrong.
    ~Blobeye Syndicate Member #2442~
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    +1
    The EJ205 is an interference engine. Should the timing belt snap, the valvetrain will likely be compromised. As SD mentioned, consider timing belt replacement a necessary precaution.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Sep 2010
    Orange county
    Starting Point.
    Front of my car!
    Back.. lol how exciting haha...
    Sorry My car is stock but Hopefully with some time i can make some changes.
    Registered User LetsWRCinmyWRX's Avatar
    Dec 2009
    Invidia N1 FTW
    Bugeye Mafia #155
    Friends don't let friends drive stock.
    Racing a neon is like fighting a girl: you can't brag about it if you win, and you don't want anyone to know if you lose.
    facebook
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by LetsWRCinmyWRX View Post
    Invidia N1 FTW
    no.
    Facebook me here
    May 2008
    Florida Panhandle
    Do your timing belt.
    http://www.importimageracing.com/p/S...7-WRX-STI.html
    This is an awesome kit, I've installed this kit on a couple of Subaru's already and it comes with everything and it's cheap.
    I would get a compression tester, you can usually rent one from autozone. I would check the compression, make sure everything is running solid before you start modifying it. It's cheaper to fix a problem before it happens. How is your clutch? If it's the stock clutch, it's definitely going to need to be replaced if you want to go Stage II and still keep your car reliable.
    There is plenty of used turbobacks on here or on nasioc. You can usually pick up a full setup for under
    $500, then get a used accessport for around $500. Stage II is an awesome place to start, and relatively cheap to do. I would stay away from an STI or SPT exhaust, it is not much better then the stock exhaust you have right now.
    Sep 2010
    Orange county
    So i have ordered an up-pipe from an 04 WRX actually from one of our clubwrx members. As soon as i get it i will be installing it.
    Timing belt maintenance will happen tomorrow yay!! 1085. Sadly i dont have time to do it myself atm.
    Oh yeah I also purchased a replacement turbo from one of our users. I will keep this one in the garage as my car is still spooling to .08-.1 MPa so im guessing the turbo is still in good condition.
    should be a fun week. i will post pictures.
    Sep 2010
    British Columbia
    you'd be a fool to not replace the timing tensioner and pulleys during timing belt replacement as these parts are hardly greased to begin with and are ENGINEERED TO FAIL
    zax
    zax is offline
    Nov 2008
    Did you purchase an aftermarket turbo or did you find an OEM TD04-13T? If it's the latter, why??
    Facebook me here
    Registered User WRX-KING's Avatar
    Sep 2010
    408, CALI
    clean ride. congrats!
    Sep 2010
    Orange county
    Update!
    SO i got my car back tonight!
    I changed the timing belt kit, Timing belt HYdraulic, tensioner, thermostat, Waterpump, Cam seals, and some other seal i couldnt tell what it syays LOL. New serpentine Belts.
    So the car is good for now. I might change the tranny fluid but im not sure what synthetic to use yet or how much i need.
    I have decided to buy a used tsudo catback for pretty cheap. I know its loud but its a pretty nice deal so i kinda want to pick it up and keep it for a few months till i can save for a better one later if i dont like the sound.
    LOL, everytime i drive by a Subaru driver they give me a peace sign so from now on i will give any of you a peace sign if i see you on the street.
    -Sal
    Sep 2010
    Orange county
    Update...
    Hey,
    I have installed just installed the TSudo catback. Overall the car is pretty loud even with the silencer on but i love the sound.
    some picts:
    Next mod is the Up-Pipe which im still waiting for ... ill post picts when i get it.
