Stock 2007 WRX Limited - Page 2
Results 16 to 30 of 33
This is a discussion on Stock 2007 WRX Limited within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Can't... fight it... Yo man you gotta get that limited 4eat some dollar bills in the gas tank so you ...
    May 2010
    Pittsburgh, PA
    Yo man you gotta get that limited 4eat some dollar bills in the gas tank so you can some smoke STis.
    ....Had to say it
    Honestly nice car. Enjoy it, and make sure you take your time and research everything very well.
    2011 STi Build Log
    Registered User kbrownmann's Avatar
    Nov 2009
    Melbourne, Kentucky, United States
    ....Had to say it
    + infinity
    Hawk-Eye Alliance #Infinity
    Registered User Brandon23's Avatar
    Aug 2010
    Seattle
    Ha well if your thinkin that its an automatic your wrong. Its a 5 speed.
    Thanks tho
  6. #19
    Nov 2009
    Quote Originally Posted by Brandon23 View Post
    Thanks tho
    haha no its an inside joke
  7. #20
    May 2010
    Pittsburgh, PA
    2011 STi Build Log
  8. #21
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    The WRX limited is a very nice car. A nice step over the typical low-quality setup of the WRX interiors. I would suggest you keep that in mind before you start slapping gauge packs here and there. This is the kind of car that will make a nice transition to your grown-up years. But, ultimately, it is your car, so do with it what you will.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  9. #22
    Aug 2010
    ....Had to say it
    oh common guys he doesn't even know about the magic auto limited edition WRX woopen them STIs XD
    :] anyway, welcome to the club man, you will absolutely love your WRX :] whenever you have a Q needing an A, come here these people really do know a insane amount about these cars :]
    to be honest i would rather go the handling way before Power, because its better to drive fast safe, then faster and not safe you know what i mean?
    Strut Braces, Front and Back:
    from M2 Performance, the site is not loading up, so i will post it up latter.
    These are not the bast, but on a tight budget they do the job+
    Struts:
    I would try try to get some OEM STI struts with aftermarket springs until you get the money to buy coil-overs.
    Springs(S. Tech):
    http://www.jscspeed.com/catalog/Suba...ubaru_STI.html
    Get these only if you get the anti-lift kit, because it drops your cars hight which makes it annoying in winter.
    Anti-Dive kit(first posting, race kit):
    http://www.jscspeed.com/catalog/Suba...u_WRX_STI.html
    If you get those springs above, it will make your car about stock hight.
    Sway bars would be a good idea, but they are pretty expensive, because the end-links to match are about as-much and the bars themeless:
    Sway Bars(Front and Back):
    http://www.jscspeed.com/catalog/Suba...ubaru_WRX.html
    End-links(Front and Back Second Posting):
    http://www.jscspeed.com/catalog/Whit...uty_Alloy_1842
    all together this should run you about 1289$ plus shipping.
  10. #23
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by ShinceN View Post
    Springs(S. Tech):
    Tein S-tech springs suck.
    I'd upgrade your sways before you upgrade your springs. Perrin sells the package F/R sways, endlinks, stout mounts, and hardware for about $700. You can find the package discounted for about $500. With lowered springs and an Anti-lift kit, you will need to have a camber alignment done, so keep that in mind. It may run you around $300 for the full alignment.
    Facebook me here
  11. #24
    Jul 2004
    Seattle, WA
    The interior isn't that different, when comparing the Limited to a standard WRX.
    When you're sitting in the driver seat the only difference a Limited WRX driver will notice is the seats are covered in leather below and there is a sunroof above.
    On the gauges, I suggest going with an over the steering wheel column approach. With a boost and oil pressure gauges.
    http://www.rallysportdirect.com/shop...mm-p-1372.html
    A-piller pods reduce visibility on that side of the car too much. Clock pods are good, but then you loose the clock ;p
  12. #25
    Strut braces are more bling than function (with the exception of a rear strut brace on wagons); I would hold off on that until you've pretty much finished your suspension.
    Struts:
    The only compatible struts would be '04, and while capable and a decent upgrade, there are better options.
    Springs(S. Tech):
    Unless you're strictly looking for an aesthetic upgrade, do not buy these springs.
    http://forums.nasioc.com/forums/show....php?t=1267918
    I'll preface this criticism with the following: ALK is my favorite suspension modification so far. With that said...
    If you plan on competing in motorsports (one of the best and most fun things a car enthusiast can do), check to see what this does to your classing. In SCCA Auto-X rules, an ALK rapes you, and would put you in a class that you have absolutely no chance competing in if you don't have >$10K invested in the car.
    Resident Tuner @ WTF Tuning
  13. #26
    Aug 2010
    Seattle
    Okay thanks guys. i stated researching and i think im going to start will a full exhaust and possibly access port v2...
  14. #27
    zax
    zax is offline
    Nov 2008
    Okay thanks guys. i stated researching and i think im going to start will a full exhaust and definitely an access port v2...
    If you go with a full exhaust, the accessport (or some sort of tune) is a must. So I fixed it for you!
    Facebook me here
  15. #28
    Aug 2010
    Seattle
    well i guess there is a guy that has a shop near where i live that will tune it for me if i buy the full exhaust through him and have install for around 500
  16. #29
    zax
    zax is offline
    Nov 2008
    not bad. But make sure that you have a way of switching between tuning maps. i.e. Romraider + tactrix cable
    Facebook me here
  17. #30
    Aug 2010
    Seattle
    well since his shop is close, i probably could just go ask him! but ill keep that in mind.
    what are the difference between maps?
