check engine light...pcv valve?
Results 1 to 3 of 3
This is a discussion on check engine light...pcv valve? within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; so im throwing a check engine light on my o4 wrx. it runs fine no leaks or anything the cylinders ...
    Aug 2010
    ny
    so im throwing a check engine light on my o4 wrx. it runs fine no leaks or anything the cylinders arent mis fireing my gas caps on tight ect. could this be from a boost leak? im losing power and it lags in first gear wen it never use to. new pcv valve ?
    Registered User Crb03's Avatar
    Jan 2008
    southern cali
    First step is to pull the CEL code. Then you should do a search on the code and find out what it is.
    "M3 drivers have no friends..." - Jeremy Clarkson
    "If something sounds too good to be true, it's best to shoot it to make sure" - Fiona Glenanne
    Aug 2010
    ny
    Quote Originally Posted by Crb03 View Post
    yeh thats wut im doin, a friend from a shop is comin ovr to check it out rite now
