Results 1 to 4 of 4
This is a discussion on stage 2 clutch grinding within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; My stock clutch just wasn't able to handle the torque of my exhaust and catless dp... so i ordered a ...
    Jul 2010
    My stock clutch just wasn't able to handle the torque of my exhaust and catless dp... so i ordered a stage2 clutch and flywheel and had it installed. The only problem is when i begin slowing down i hear/feel a grinding. I'm assuming its the flywheel and new clutch being worked in but i' not positive. HELP!!!! I dont want to hurt my bugeyed baby!!!!
    Registered User wrxlaunch's Avatar
    Apr 2008
    DC,MD,VA
    Quote Originally Posted by russ3331 View Post
    What u mean can't handle the torque...? Maybe it was on its way out and those mods helped to speed up the process... The oem clutch is more than enough to handle a stage 2 bugeye. Why stage 2? Guess u didn't do ur homework on that one.
    VF-43 Bugeye: OPEN SOURCE tune... 121xxx miles
    13.1@105... Lazy launch 1.9 60'
    285whp and 300WTQ.
    Feb 2010
    SL,UT
    Quote Originally Posted by wrxlaunch View Post
    +1
    Are you sure you didn't just go out and beat it up? It could've been installed wrong or off and was the flywheel machined to the right specs?
    Hawk-Eye Alliance #801
    Yes... you need engine management for engine modifications
    http://www.clubwrx.net/forums/tuning...ne-mods-6.html
    Oct 2008
    ACT
    Was it a light weight flywheel that you put in?
    If it was - that's what's causing the grind noise on decel.
