I guess I can't talk like a man. So this is the repost
Results 1 to 15 of 17
This is a discussion on I guess I can't talk like a man. So this is the repost within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; I finally got my 05 WRX. I feel like I might have been SCREWED over. Long story short. I traded ...
    Registered User Tattooed11Bravo's Avatar
    Jun 2010
    Honolulu Hawaii
    I finally got my 05 WRX. I feel like I might have been SCREWED over. Long story short. I traded my VERY clean 03 G35 in for this 05 WRX. There's a few small thing I need to fix and that's no big deal I expected this. But when I got in my car this morning there was a Good size puff of white smoke that came from the exhaust. I have checked my oil, looks/smells good. Checked the radiator fluid looks good. Oh yeah. I forgot to tell you that all the fluids were changed 3 days ago. It was also inspected by the mechanic and he signed off saying it was good. I have a horrible feeling that I'm going to have to replace the gasket.
    What do you think???
    P.S
    There is no oil leaking from under the car, so I don't beleive the block is cracked.
    Thanks for reading
    Administrator
    May 2003
    If you consider taking it in the ass talking like a man, I'd hate to here girl talk.
    Registered User GrtScott's Avatar
    Apr 2010
    Los Angeles
    Was it a one time thing only?
    If not... my spidey senses tell me it's your head gasket.
    Jun 2010
    Honolulu Hawaii
    I just said that cause I got an e-mail saying I can't use that kind of talk cause people of all ages red these treads and it offensive. So i figured I'd be a smart ass with the title
    Jun 2010
    Honolulu Hawaii
    GRTSCOTT
    I just got the car last night. So this is the first morning that I had the change to start it. When I went to the dealer and he started it for the first time that day i didn't notice that it smoke. I'm hoping maybe they just put to much oil in or some ****. But I checked the stick and it looked fine. I'm sure it's the head gasket. I found some for $60 shipped. It's just getting to those things is what's going to be a pain
    Is the car stock?
    How many miles?
    Before tearing into anything I'd at least test both the cooling system and the cylinders. There may be nothing wrong with your car.
    Jun 2010
    Honolulu Hawaii
    The car is mostly stock from what I can tell. The guy who owned it before me put a HKS BOV and a boost control that sits in the engine compartment ( I can take pic of the engine if you'd like) It has 70k. What's the easiest way to check that stuff, just take it to someone?
    You can check the cooling system by renting a tester; it's a rad cap with a hose attached and a manual bellows that allows you to pressurize the system when the motor is off. You measure pressure loss with an attached manometer.
    Do you only get this smoke at cold startup?
    You could start on the motor with a compression test but would then look into some sort of leakdown test depending on your results.
    This is all still a shot though since even if you do have water loss into the cylinders it does not have to be the head gasket(s).
    Is the CEL on?
    Jun 2010
    Honolulu Hawaii
    No the CEL isn't on. The cars running great. It's just the white smoke on cold start.
    Keep an eye on oil and water levels over the next few weeks.
    You could consider an oil analysis (see Blackstone Labs) as that'd tell you if there is water in the oil definitively.
    If the car is not running stock boost and is not mapped for whatever parts are on it, either return it to stock or get it tuned locally.
    Jun 2010
    Honolulu Hawaii
    Ok i will keep an eye on that stuff and find someone to tune it. Thanks for the input. I just hope it doesnt get worse over time
    We don't know what, if anything, it is yet. The car has been modded though so a thorough looking-over would be good. Since you did take it to a mechanic before buying you've done something to stack the cards in your favour.
    Look around the links in my signature for more info, and check out the maintenance and other fora too.
    Congrats and good luck.
    SD
    Registered User Semaj07's Avatar
    Jan 2010
    Holbrook, NY
    I am by no means an engine or a subaru expert, but I am thinking MAYBE the previous owner used some SeaFoam cleaner on it before it was sold? Just to clean out the internals. Could just be some residue left over. But good luck and let us know if anything is found.
    Stink-Eye Member #83
    2010 WRX Hatch Limited, Obsidian Black Pearl with Sports Grille
    Tinted windows/tails, TurboXS CBE
    Jun 2010
    Honolulu Hawaii
    So to day was a much better day. Yesterday after triple checking all the fluids and having them turn out fine I had noticed something. The guys who changed the oil from the dealer had forgotten to put 2 quarts of oil in the car. So i bought a quart of that high speed engine oil (sorry I'm having a brain fart on what it's called) followed by a quart of oil.AND......... when I started the car up this morning. NO SMOKE. So I hope it stays this way. Thanks to all for the help. Take care all.
    Dec 2003
    Dallas, TX / Sterling, VA
    Car is incorrectly modded and that can lead to problems. Though there could be nothing really wrong.
    ~5 yrs ago my WRX would leave a spy hunter smoke screen upon start up until it warmed up. After 5 or so months, it stopped and totally went away. No missing coolant, no missing oil.
    [edit] You updated while I was typing. High speed engine oil + regular oil?
