Results 1 to 10 of 10
This is a discussion on Lowering 02 wrx. Which spring is front/rear? within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; So i ordered the TOKICO suspension kit and they sent me the box with everything thrown in...Im use to cobalt ...
    Dec 2009
    New Hampshire
    So i ordered the TOKICO suspension kit and they sent me the box with everything thrown in...Im use to cobalt springs which are 2 completely different types but the subys seem to be almost the same. Which one is the front and which one is the back? Thanks guys!
    2009 White Cobalt SS Coupe Turbocharged
    1 of 118 White Cobalt SS Turbo Coupes Ever Produced!
    Dyno: 293WHP 334WTQ SMG HPTuned!
    GF's Car - 2002 Subaru WRX (Stock..for now)
    Registered User Uh Oh's Avatar
    May 2010
    Charlotte, North Carolina, United States
    The longer, thinner one is for the rear.
    Dec 2009
    New Hampshire
    Quote Originally Posted by Uh Oh View Post
    the one with more coils? are you 100%?
    Quote Originally Posted by MkUlrey13 View Post
    It won't matter, as the springs you remove will be analogous.
    Dec 2009
    New Hampshire
    My front and rear stock springs are exactly the same.. Thus why im asking. On cobalts they are completely different and cannot me used vice versa where these seem to fit eitherway.
    May 2010
    If you're stock ones are identical front to back...are you sure you've received the proper springs for your car?
    If those are correct, yes, the one with more coils is for the rear.
    Dec 2009
    New Hampshire
    Yes i recieved the correct springs for a 02-03 wrx 4dr not a wagon. I will proceed with installing them with the more coiled one in the rear. Thanks guys!
    This thread contains pics of the stock items. They should be analogous to what you are installing so you should be able to tell front from rear:
    http://www.iwsti.com/forums/how-inst...l-springs.html
    Toboggan T0rque's Avatar
    Dec 2004
    Your Mommas
    LOL if you do it wrong the rear end will be pretty close to dragging muffler..
    Lead Wrench @ WTF Tuning, LLC
    The only way I can think of for the front and rears to look similar is if the previous owner had switched to a coil setup or something -- the stock items are quite different, and so are all the conventional aftermarket replacements I've seen.
