Results 1 to 3 of 3
This is a discussion on breen9268 within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; hi new to the site,and need some advice, i have a2006 model 2.5turbo wrx,just noticed a whine from transmission,more noticeable,when ...
    Jun 2010
    breen9268
    hi new to the site,and need some advice, i have a2006 model 2.5turbo wrx,just noticed a whine from transmission,more noticeable,when the car is labouring at 2000rpm and you accelarate slowly,also becomes more prominent,when traveling,through built up areas any ideas, or is this normal
    Not enough info. Could be normal but we can't tell. It's probably best to have someone local listen to it.
    Toboggan T0rque's Avatar
    Dec 2004
    Your Mommas
    Could of had straight cut gears installed or some other trans rebuild.
    Lead Wrench @ WTF Tuning, LLC
