Nice car!
This is a discussion on Hi, i would like to introduce Suki. within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Hi, i would like to introduce Suki, She is a 2000 V6 WRX STi Type R Coupe, She's magnificent, just ...
Hi, i would like to introduce Suki, She is a 2000 V6 WRX STi Type R Coupe, She's magnificent, just awesome to drive.
Here are some of the features of this car
WRX STi Type R Japanese Specs, The STi is far from standard
Forged Molybdenum Coated Alloy Pistons, Sodium Filled Exhaust Valves, Hollow Inlet Valves Deal With The Higher Revs & Greater Heat
Metal Gaskets & Heat Proof Red Coated Manifold
Reinforced Larger Intercooler, Intercooler Water Spray, Revised Larger Intake Manifold, Teflon Coated IHI VF28 Turbo-Charger @ 16.8 Psi
Larger Capacity Exhaust System
STi Quick Ratio Power Steering, 4 Pot Ventilated Front Brakes, 2 Pot Rear Ventilated Brakes
Titanium Strut Brace by FHI Aerospace Division, Alloy Suspension Arms To Reduce Unsprung Weight, Inverted Strut Suspension
STi Double Pressure Heavy Duty Clutch, Reinforced Rear Axle
Close Ratio Gear Box
The STi type R coupe has a viscous limited slip differential in the front axle. An electronically controlled differential in the centre which can be altered from free to 100% locked. Also a 4 way 2 pinion mechanical differential in the rear.
Horsepower figures
280 hp at 6500 rpm and 260 lb-ft of torque at 4000 rpm (100 RON)
206kW at 6500rpm and torque 353Nm at 4000rpm (100 RON)
Versus 160kW at 5600rpm and 290Nm at 4000rpm for the std WRX
Compression Ration 8.0:1
1-100km/h in 4.9 seconds (100 RON)
16 Inch Rays Lightweight Racing Gold Alloy Wheels
Roof Air Vent, Full Sti Spoilers, Including Front, Rear Spoiler, Side Skirts
STi Blue Racing Seats, Leather MOMO (Airbag) Steering Wheel & Gear Knob
STi Hot White Dials in a Blue Dash Panel and Blue Fascia Panels, STi Limited 346/1000 Plaque / Subaru WRC Limited Edition
The factory STi computer is excellent, but has 3 shortcomings.
1st - it is tuned for 100 RON fuel, I use BP Ultimate 98.
2nd - it is tuned extremely safely and runs very rich.
3rd - it has factory limiters - 180k speed, revs, power.
Modifications
Enkei 17" Racing Alloy's with Toyo R888 Tyres
Tein Super Street Adjustable Suspension
EBC GD Slotted Front Rotors with EBC Yellow Stuff Brake Pads Front and Rear
STi 1.3 Bar Radiator Cap
Hey
( it's just my opinion, besides my WRX it's all i have )
Disclaimer
I cannot guarantee the accuracy nor intelligence of my opinion. But promise to express it free of charge.
Nice car!
This is where subaru fell short with the 2011 STI sedan! They should have made a 2 door version...
Nice car dude, 2 door FTW!!!
**__The Hawk-Eye Alliance__**
Member #0135
Like life, fashions tend to go in cycles, coupe's will come back and FHI will once again attack the WRC with a Subaru.
I wanted a V8 coupe and was gutted they stopped making coupes at V6. I looked at quite a few Type R's but they were all modified with either FMIC's, body kits or V7 engine transplants then 2 years ago i came across this fresh factory standard import and wow i've never been so lucky in all my life.
I'm one very happy Subie owner.![]()
Hey
Disclaimer
welcome mate, nice looking "classic" coupe
ScoobyDMC #000,HawkEyeAlliance#000,Blobeye Syndicate #000, SQC-NY #009, "Dragon Slayer"
"All We'll Drive"
I <3 boobies: rallyarmor/keepabreast/mud flaps limited edition
sweet car! thanks for the history lesson too, didn't even know subaru made v6 sti's, let alone any non-boxer sti's.
STINK-EYE MOB #15 ||
Wow very nice ride man, welcome. I love all these new people popping up with awesome classics.![]()
"M3 drivers have no friends..." - Jeremy Clarkson
"If something sounds too good to be true, it's best to shoot it to make sure" - Fiona Glenanne
heh v6 stands for version 6 not v6 engine i believe it is a 2.0L turbo boxer 4 in that..
v7 is the bugeye style then v8 is what came after etc etc...
LIVE LOUD, ROCK HARD!!@
2003 WRX wagon 16g + 6 speed
ahhh so jealous! nice car
Hawk Eye #1991
Dirty Crew #11
Military Militia #1991
I still don't know how I got this car...
V6 = Version 6 last of the classic or original shape impreza, mine has a 1994 cc boxer engine and VF28 Turbo.
V7 the new improved faster stronger Bugeye, V8 V9 V10 Hawkeye.
What version is yours ?
Or is the term version not used, perhaps version is just used down here in the underworld as the Subies main competition are Mitzi Evo's and they use a similar numerical designation.
I'm no subie expert or historian, i have tried to learn about the WRC Limited Edition models but have found very little on them.
If any of you know the history or specs of these cars or can suggest where i could look i would be very grateful.
wayne
Hey
Disclaimer
that makes a lot of sense. was scratching my head... how would a v7 work![]()
I would like enhance Suki's STi heritage by using STi pink parts where possible.
HANDLING = STi Lateral Link 3 Pilo GC8, STi Trailing Arms, Whiteine Front and Rear Stabilizer Bar, ELECTRONICS = STi 280 kph Speedo, Apexi Power FC ECU, Apexi RSM Speed Meter, Apexi RSM Stand, Apexi RSM Shift Light, Hella Spread Beam Driving Lamp - Blue Lens, POWER = Venom VCN750 Computerised Nitrous System, INTERIOR = Momo Performance Blue Gear Boot, Momo Combat Evo Blue Shift Knob, MAINTENANCE = STi Oil Filter, STi Cambelt
Advice, opinions and recommendations welcome
Hey
Disclaimer
Wayne,
you may also want to check out whiteline swaybars and endlinks for the gc8 classic , also i think they make steering rack bushings too
main website: http://www.whiteline.com.au/index.php
"All We'll Drive"
Ok quickie lesson for some of the peeps who dont understand the earlier generation GC8 "classic" impreza's
The "classic" had many a variation of STI's called version 1 thru version 6 in Japan. so when Wayne here says a V6 impreza he doesnt mean its a V6(as in a engine) he is meaning its the Version 6 incarnation of the classic impreza or the last of the classic generation before the bugeye came out.
Japanese-spec
* Version I (10/92 – 08/94) - GC8A/B
* Version II (09/94 – 08/96) - GC8C
* Version III (09/96 – 08/97) - GC8D
* Version IV (09/97 – 08/98) - GC8E
* Version V (09/98-08/99) - GC8F
* Version VI (09/99-08/00) - GC8G
Nice read:
http://en.wikipedia.org/wiki/Subaru_...1992_-_2000.29
"All We'll Drive"
