Results 1 to 4 of 4
This is a discussion on Repaint or Replace? within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; I have a 2002 WRX wagon, Subaru Blue color. The paint on the hood on what I think is called ...
    Jun 2010
    Repaint or Replace?
    I have a 2002 WRX wagon, Subaru Blue color. The paint on the hood on what I think is called the air intake (the part in the middle of the hood that rises above the rest) is bubbling and chipping off. I went to a body shop and they were going to charge $300 to repaint it to match the rest of the hood. A friend suggested that I just replace this with a used air intake and said that it shouldn't be that hard.
    How much would it cost to buy a replacement? How hard is it to replace (I'm a girl with not much car experience but somewhat mechanically minded Where should I buy it?
    Thanks for any input and suggestions.
    SusieWRX
    Call around your local wrecking yards. Many cars are owned by elite, highly skilled drivers and as a result get driven into trees, so spares should not be hard to find. See if you can find a replacement in better shape than what you've got.
    Also, shop around body shops because prices vary dramatically.
    Incidentally, I doubt the nose of the car is in great shape, right? If the hood scoop is hurting the nose must be chipped too. You may want to ask around friends/relatives/etc. for a good place and if you are going to keep the car, see what it needs as far as paint -- it's cheaper to do it all at once rather than piecemeal. It's not inexpensive, mind you, but it's less.
    Registered User BenS's Avatar
    May 2010
    STINK-EYE MOB #15 ||
    Registered User poly_poly-man's Avatar
    Feb 2010
    Rochester Institvte of Technorcery
    Quote Originally Posted by SusieWRX View Post
    SusieWRX
    Welcome!
    The color is officially called World Rally Blue (WRB for short). The air intake is actually a thing inside the engine compartment, near the front and on the passenger side - to what you're referring is the hood scoop - takes in air and pushes it through the intercooler.
    You have a couple of options regarding your hood scoop.
    #1: paint it yourself. You can buy the official paint online, and it's just a simple, three-part spray paint job - the hardest part is taking off the old paint, which should be free (but not necessarily easy - ask someone who knows bodywork).
    #2: buy an unpainted scoop, paint it yourself or get the guy to paint it - will be easier, and probably cheaper because it requires no paint removal.
    #3: buy a painted scoop. Harder to find and more expensive, but nice, easy solution.
    Looks like you'll probably find a solution with some searching for around $250 (painting yourself - a LOT cheaper. Ask around to see if you want to try it - again, not a bodywork expert )
    Plus, solutions 2 and 3 give you the chance to get more airflow and a better look with the jdm sti scoop - a bit more aggressive looking.
    Anyway, good luck fixing this - those little things can be the most annoying!
    My big thread: The Used WRX Buying Checklist - Please Contribute!
    My current car: 2002 WRB WRX Wagon.
    Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
