Noise over bumps, need advice please.
Results 1 to 6 of 6
This is a discussion on Noise over bumps, need advice please. within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Hi everybody, i'we been reading all posts, searched google, but found almost "0". Car 2003 WRX , 136*** miles, no ...
    Registered User volodyalysak's Avatar
    Jun 2009
    Colorado
    Unhappy Noise over bumps, need advice please.
    Car 2003 WRX , 136*** miles, no mods to engine, no mods to exaust etc.
    Only upgrade is:
    4 tokico d-spec adjustable shocks struts i belive on stock springs with stock top mounts.
    I got my car 6 month ago, all was fine and tight, after my trip to San Francisco from Colorado my rear driver shock quit, i found 2 used shocks to put in the back of my car for 50$, while i send my bad shock to be replaced under warranty. It happened in September, and i got my new shock in February, so my friend/mechanic took out old ones and put new ones back in.
    All top bolt tight and springs installed correctly.
    My problem is:
    Well i have this awful noise from the back especialy when going over cracks in the road, potholes, even if it's 0.5 -1 inch deep. Sound like something loose, and metal binds to the metal, when under car, can't find any loose parts, don't know what bushings should look like, but seems to me they ok. And the noise is the worst when i go over bump and turn, it feels like whole back going to fall apart, it like you hit the metal covered with plastic.
    The same sound comes from front but quiter with the same symphtoms.
    It's quiter when it raining outside .......
    Help me to identify, or if anyone lives in Denver and willing to help me to identify the problem before i waste my money, i was thinking to replace all bushings , but have no idea if it going to help.
    Any reply and advice will be hightly appreciated from you.
    Registered User T.J.'s Avatar
    Oct 2002
    on a boat...
    The common problems to look for are worn stabilizer bushings and end links.
    I know you have already done this but all I can suggest is to get under the back of your car and push/pull the ends of your stabilizer bar and see if there is play in the bushings or end link.
    I have one of each to replace on my Impreza and the wife's Forester right now.
    Good luck, T.J.
    200,000 mile club.
    Old Irish adage: "Do not resent growing old. Many are denied the privilege."
    Jun 2009
    Colorado
    How hard would be to replace them ? Which one would you suggest ? Any DIY or tips ?
    Thanks
    Oct 2002
    on a boat...
    I would suggest replacing which ever one rattles when you shake it.
    Pretty easy to replace either. It will be self explanatory when you look under the car. If not, this thread should cover it: Rear Sway Bar/EndLinks Install
    Hell, while you're at it you might as well just replace the rear bar and end links for better handling. The new bar will come w/ new bushings.
    200,000 mile club.
    Jun 2009
    Colorado
    The problem is ,when I try to find a rattle it's all solid ,as soon as. I hit any bump/crack it rattles ,binds.is any way to find out what exactly need to be replaced? I don't have enough money to replace all bushing endlinks and sway bar.thanks again
    Registered User dehnem's Avatar
    Mar 2006
    Wisconsin
    did you replace your swaybar as upgrade? or was it out of necessity?
    96 Mustang: Shorty Headers, X-pipe, Electronic cut out, Air silencer Delete, K&N air filter, really sticky tires
    (14.32 @ 96.7mph)
    02 bugeye: exedy oem clutch, kybAGX struts, momo short-throw shifter, steel braided brake lines, stoptech rotors and stock rims (the 17inch wheel just weighed too much), 14.232 @ 94.75mph
