Cold Air Induction Kit
Results 1 to 9 of 9
This is a discussion on Cold Air Induction Kit within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Hi guys. I was wondering if anybody could give me some advice!? I have a 2004 Impreza WRX, I've recently ...
    Registered User loua84's Avatar
    Dec 2009
    Hi guys.
    I have a 2004 Impreza WRX, I've recently fitted an AEM cold air induction kit. Yesterday I was told by a Subaru mechanic that I might blow a piston with that kit on. Is this true is it possible?
    Thank you for your help
    Kind Regards
    Lourens
    Registered User wrx1234's Avatar
    Sep 2009
    Dover DE
    I'm no expert. From lurking and reading through these forums it seems that using an intake causes the the engine to run lean due to the increased airflow. I would stay out of the turbo and get a tune as soon as possible. I haven't heard about anyone blowing a piston, but running lean can't be good.
    Registered User JUSTINSNUTSWINGER's Avatar
    Jul 2008
    San Antonio
    Are you running any engine management ?
    N-swinger
    2000 Escort
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
  5. #4
    Moderator Donkey's Avatar
    Da boonies,Va
    The problem with intakes has nothing to do with more airflow. The problem has to do with how the MAF system was designed for Subarus and how the Openloop fueling works. If the intake causes to much turbulence or has a larger than stock inner diameter MAF housing the MAF signal is no longer calibrated. In Openloop fueling the ECU does not use the O2 sensor feed back and relies on the MAF signal as the primary fueling sensor. Closed loop fueling uses O2 sensor feed back to make corrections to fueling.
    CobbTuning.com - Aftermarket Intakes
    2002 FORESTER S
    1998 FORESTER S
  6. #5
    Older AEM intakes weren't properly-designed and could screw with the MAF readings. They have since supposedly remedied the problem. Whether or not you have the newer revision, I'm not sure.
    2005 WRX STi (Mods | Virtual Dyno) - Weekend Warrior
    Resident Tuner @ WTF Tuning
  7. #6
    Dec 2009
    Quote Originally Posted by pzr2874 View Post
    Hi, no i haven't added or changed the management.
  8. #7
    Dec 2009
    It is quite a large diameter pipe, would you suggest to rather remove the induction kit and put the original on?
  9. #8
    Dec 2009
    Hi, the intake's diameter is quite large, would you suggest to rather replace it with the original?
  10. #9
    Da boonies,Va
    The MAF housing in the stock airbox is 65mm. If the intake is larger than that then yes replace it.
    2002 FORESTER S
    1998 FORESTER S
