advice 2006 wrx wagon
Results 1 to 6 of 6
This is a discussion on advice 2006 wrx wagon within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Ok after reading Big Sky threads about wagons and suspensions I couldnt find a solution for my "problem" because the ...
    Sep 2009
    North Jersey
    Ok after reading Big Sky threads about wagons and suspensions I couldnt find a solution for my "problem" because the thread ends in 2007?!?
    I want to lower my wagon a little bit without the "SAG ASS" problem ,and winning on the performance side. I read about the sti pink springs that were doing the trick by then, but is there nowadays something else out there wagon intended?
    thanks
    Dec 2003
    Dallas, TX / Sterling, VA
    Sep 2009
    North Jersey
    thanks but actually looking for springs that will lower the wagon a little bit
    Jul 2004
    Seattle, WA
    brfatal, that's an interesting product, I've not seen that before.
    RicardoPT, it looks like you can buy what ever springs you want, then if they lower the butt too much, just get these spacers, install them, and it will raise it up that much.
    Registered User srcjrs's Avatar
    Aug 2006
    good for 10mm: STI spec C springs, the regular black ones, worked perfect to drop my wagon about 10mm or 3/8 of an inch. I also added STI rear struts, and sway bar and am very happy with the ride and handling improvement without being too rough on the daily commuter. just a cheap budget idea. I picked up the springs and struts on craigs list with only 30k miles on them for $100. I'm only bummed that they came from an 05 so I couldn't use the front struts too
    Wagons Rule!
    Aug 2006
    here's a couple pics:
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    maybe you'll find this helpful. It is a little saggy in the back, but not near as bad as some i've seen on regular lowering springs. Let me know which route you take on this one, since I'm always looking for something new to try too!
    Wagons Rule!
