Tuning
Results 1 to 12 of 12
This is a discussion on Tuning within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; I am new to tuning. Can someone please explain to me how i get to different stages and where i ...
    Sep 2009
    duluth, MN
    Tuning
    I am new to tuning. Can someone please explain to me how i get to different stages and where i can get my car tuned?
    Dec 2003
    Dallas, TX / Sterling, VA
    TurboXS was the 1st to successfully market staged packages, so as a rule of thumb:
    Stage 1: Engine Management
    Stage 2: Engine Management + Turboback
    Stage 3: Engine Management + Turboback + Bigger TMIC
    Stage 4: Engine Management + Turboback + Bigger TMIC + Small Turbo Upgrade/Fuel Support Mods
    You're gonna want to see if there are any local Subaru specialty shops. If not, remote tuning is another option.
    Registered User The_Buck's Avatar
    Sep 2008
    MN
    hey man. im from duluth also, u going to UMD? also there are 2 places where you can tune around here, Rogers, MN by the cities and Tintmasters in Fargo, ND. tintmasters sucks though.
    <------------ Pure unfiltered joy... 04 wrx stage III ** The Blobeye Syndicate **... #39----------------------------------->
    Registered User Smljhndnsmr's Avatar
    Jan 2009
    -Fargo, ND
    Hey, I own a 2006 WRX TR. Recently, I purchased a Cobb TBE kit. I'm thinking it would be most wise to hold off on installing it until I purchase an AccessPORT 2.0, yes? I understand that the typical order of stage modification is first to tune, then to install a TBE, and so on, but does the installation of a TBE kit result in the need to retune the ECU even if an aftermarket ECU remapping has already happened? Basically, I'm very interested in learning more about the fuel ignition timing remapping/tuning aspect of vehicle modification - the do's, the don'ts, and everything else I ought know before I go and damage a perfectly nice engine.
    Jan 2009
    -Fargo, ND
    I should also add that my 2006 WRX currently has installed a K&N Typhoon Intake kit. A foolish decision on my part? I honestly do not know. What I guess I would like to know most is whether the presence of this intake kit will be cause for a tuning issue when it comes time to install a Stage 2 map. Will it or do I have nothing to worry about? On that note, does such an intake kit as this even produce power gains without tuning, a TBE kit, and/or other modifications? I know full well that it's functioning, as the sound of it operation is quite evidently louder than the stock box assembly, but is it really a worthwhile investment without other modification supplementation? = me?
    Dec 2003
    Quote Originally Posted by Smljhndnsmr View Post
    Yes, however once you have your mods established or have it a holding point where you will mod later you really should get a custom tune instead of using the crappy OTS maps. You won't regret it.
    How was this a bad decision exactly? You will make more power than you would without it.
    Jan 2009
    -Fargo, ND
    Quote Originally Posted by brfatal View Post
    What I was getting at, I guess, is the risk of damage to the turbo and/or other significant parts. Without tuning, does a performance cold air intake kit carry the potential for causing dangerous changes in pressure in the same way that a wider-than-stock TBE kit apparently does?
    Also, the other item of interest I was trying to figure out was the straight-out-of-the-box power benefits of hardware upgrades. For example, the intake kit I purchased is listed by the manufacturer as adding 15.85 HP @ 5050 RPM. Are estimates, such as this one, stand-alone estimates of the individual parts (barring the presence of any other aftermarket modifications) or are such power increases depended upon other simultaneous upgrades and/or fuel ignition remappings?
    Sep 2008
    MN
    as far as the 15.85 hp, thats just how it averaged on their test vehicles, every car takes to each part differently. If you had a friend with the same make/model/year and put on the exact same part it would be similar but not the same. so it is not guaranteed to be exactly 15.85, and i personally doubt an intake adds almost 16 hp.
    Additionally, I am from Hawley which is a little ways from fargo, if you want your questions answered in person you can always go to tintmasters. they specialize in wrx/sti's and can tell you pretty much anything you need to know. although i hate going there cuz they are stuck up about as cliquey as a group of 8th grade girls, but whatever.
    Dec 2003
    It depends on the intake design. The one you bought happens to be a good one and requires no additional tuning for the car to run properly (though it will still help).
    15 hp is a little high. An intake will add some power to any stage 2 and up car, how much so depends how much your setup is restricted by the stock intake.
    Jan 2009
    -Fargo, ND
    another question: if, say, a 2006 WRX were upgraded to Stage 2 and has a performance intake, how safe (or unsafe) would it be to operate the vehicle w/o the installation of an after-market uppipe that has further been outfitted with an installed EWG?
    2.5L vehicles come with an uppipe that is catless from the factory. The "required upgrade" is for the 2.0L vehicles, which came with a catalytic converter in the uppipe.
    If I'm reading your question right, you're fine.
    Resident Tuner @ WTF Tuning
    Jan 2009
    -Fargo, ND
    When upgrading from standard spark plugs to iridium spark plugs, should I be concerned with fuel ignition mapping? Would it be necessary to find a new map or would the current map (whatever map happens to be loaded at the time of the spark plug swap) be safe to operate with?
