Results 1 to 5 of 5
This is a discussion on GC8 oil leak within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; hey im a new member not sure how this works but i hav a 95 wrx gc8 wagon. i got ...
    Registered User wrx joel's Avatar
    Aug 2009
    New Zealand
    GC8 oil leak
    hey im a new member not sure how this works but i hav a 95 wrx gc8 wagon. i got it about 2 months ago and it has started leaking oil on passenger side from cam cover. i do not know much about subaru's yet so am not sure what i need to replace to fix this. is this something i should get a mechanic to do for me or is it quite easy to fix. can anyone help me with this thanks
    If it's from the front it'll be a pain, if it's just a cam cover gasket itself it's not too bad but it could be tight working quarters.
    Aug 2009
    New Zealand
    thanks for the fast reply.i think it is just a rubber gasket for the cam cover. does not look easy to get to.might just give it a go though.any advice befor i pull it apart.
    Don't over-torque the bolts when you put the cover back on.
    See:
    How to change the valve cover gasket
    Aug 2009
    New Zealand
    See:
    cool thanks heaps i will give it a go and see what happens.
